07 LS460 power issues
Old Apr 8, 2023 | 03:28 PM
pbrennan56's Avatar
pbrennan56
5th Gear
Default 07 LS460 power issues
hi all, i have an 07 LS460 and having issues, my car will not start, no dash lights, no power to windows, moon roof, nothing, when i try to start the car, nothing, no dash lights, parking brake will not disengage. nothing. i can get the starter to turn when jumping it under the hood. but will not start.
Old Apr 8, 2023 | 03:45 PM
swfla's Avatar
swfla
Your battery could be shorted, not just low on voltage. This will prevent a jumper from starting your car. Take the battery to a car parts or battery store and have them test it. Typical life of battery 4-6 years.
Old Apr 8, 2023 | 08:34 PM
pbrennan56's Avatar
pbrennan56
5th Gear
i will have a look also forgot, i hooked up the scanner to check for codes and the scanner was getting "unable to connect"
Old Apr 9, 2023 | 05:29 AM
Anfanger's Avatar
Anfanger
If your ECU does not get enough power, you will not be able to use a scanner.
Old Apr 9, 2023 | 06:35 AM
ausLX's Avatar
ausLX
Change your battery
Old Apr 25, 2024 | 05:46 PM
pbrennan56's Avatar
pbrennan56
5th Gear
so I need an ecu? The one under the dash, driver side. Anyone have a part number, not one on the p
Ecu on the car.
This is the ecu under the dash, i need a part number or the right name of part?
Old Apr 25, 2024 | 06:17 PM
Gerf's Avatar
Gerf
What is going on in that picture? That may be a control unit for something but if you're looking for the engine ECU that's not it.
Balushika
Oct 1, 2025 03:13 PM
LS460AWDFS
May 2, 2024 12:40 AM
LSJim
Aug 13, 2010 12:48 PM
GSsnarl
May 5, 2006 09:22 AM
