Need Help Identifying A Noise
Old Mar 15, 2023 | 11:59 AM
cryptodonis's Avatar
cryptodonis
Default Need Help Identifying A Noise
So as some of you already know I just finished replacing my outer and inner tie rods, upper control arms, brake pads and rotors. I still have lower ball joints, and lower control arms (forward and reward) to do on my 2011 LS460 AWD. I just took the car out for a spin as it was late last night when I finished and there is a horrible almost like a scraping sound (looked under the car and it's none of the covers) now coming from the car intermittently. Anyone have any idea what this could be?
Here's a video of the noise.
https://streamable.com/xj09kr
Old Mar 15, 2023 | 01:43 PM
Anfanger's Avatar
Anfanger
Aluminum splash shields next to the rotors?
Old Mar 15, 2023 | 01:53 PM
cryptodonis
I thought this might be it also, but it doesn't appear to be. There's enough space that it isn't rubbing and clearance for turning, etc.
​​​​​​I'm really at a loss ATM so I'm going to jack up each side and remove the tires and see what I can see..
Old Mar 15, 2023 | 05:08 PM
cryptodonis
So it turns out you were 110% correct and I am just an idiot. Upon closer inspection there was some rubbing of the bottom of one of the shields against the outer rim of the rotor. This wasn't what I was hearing but it was an issue nonetheless. It was a small piece of plastic that when decelerating scuffed against the ground, but when I lifted the car it looked like it wasn't hanging low enough to scrape. Thanks again for the suggestion. Likely saved my new rotor some serious damage over time.
darchard
Jan 16, 2019 06:11 AM
jarm
Oct 6, 2014 10:25 AM
hilly35
Jul 2, 2012 06:44 AM
DGreenGS
Suspension and Brakes
Oct 5, 2010 01:04 PM
juniortai
12
Feb 17, 2010 09:47 AM
