Tachometer Stopped Working
Old Oct 22, 2022 | 04:20 PM
Catalina45's Avatar
Catalina45
Default Tachometer Stopped Working
I cleaned the MAF & throttle body today and after complete it runs well but somehow the tachometer stopped working. I searched threads and the tachometer and speedometer are on the same fuse so I need to troubleshoot where the signal got lost. Any assistance would be appreciated.
Old Oct 23, 2022 | 10:53 AM
Catalina45's Avatar
Catalina45
Disconnected negative terminal overnight and then ran a DTC check this morning which came back with no codes. It’s odd the tachometer is stuck near 1250 RPM & a reset didn’t at least “cycle” the gauge. Any help would be appreciated.
Tachometer stuck on this RPM and does not move
Old Oct 23, 2022 | 02:25 PM
ls430w140's Avatar
ls430w140
What was sprayed into the throttle body?
Old Oct 23, 2022 | 03:06 PM
Catalina45's Avatar
Catalina45
CRC Throttle body cleaners.
Old Oct 23, 2022 | 05:18 PM
CA2WALS430's Avatar
CA2WALS430
Strange. I doubt if the 2 are related. Seriously, it just sometimes happens like that, but obviously I can't say for sure. The only time I had an analog gauge stop working it was the sending unit.
Old Oct 24, 2022 | 03:49 AM
BigBoomer's Avatar
BigBoomer
Try thumping the top of the dash. The LS400 had a know issue with sticking tacho needles and a thump normally returned them to normal function.
IIRC it was caused by ancient grease getting hard and jamming the needle. The jolt dislodged it and fixed the problem.
The tacho is normally fed it's signal by the ECU these days. If a sensor plays up you will get a code and she will run poorly.
Old Oct 24, 2022 | 08:53 AM
911LE's Avatar
911LE
It's a failed stepper motor in the cluster. The ECM is still getting a signal from the crank sensor if the engine runs.
Old Oct 24, 2022 | 05:16 PM
Catalina45's Avatar
Catalina45
Thanks, makes sense as “rapping” it didn’t do anything. Is there a vendor you know of that replaces the stepper motor and rebuilds/tests the instrument cluster?
Second, are there instructions anywhere on how to remove the cluster?
Old Oct 24, 2022 | 07:14 PM
jharris400's Avatar
jharris400
These clusters don't use steppers.
Old Oct 25, 2022 | 12:25 AM
BigBoomer's Avatar
BigBoomer
Found these guys online.
https://www.instrumentclusterstore.c...t_clusters.htm
No idea if they are any good or not but may be worth a call.
Old Nov 5, 2024 | 05:35 AM
UAV's Avatar
UAV
2nd gear
Did you ever find a fix for this, mines is doing the same
Acrad
GX - 2nd Gen (2010-2023)
29
Aug 27, 2024 09:54 AM
sertimins
Apr 23, 2022 02:13 AM
datstockls
Mar 9, 2021 09:16 AM
coug66
Aug 17, 2019 10:27 PM
