Weird noise, help!!!!!!
Old Dec 2, 2021 | 07:03 PM
ToneCap0ne's Avatar
ToneCap0ne
Default Weird noise, help!!!!!!
Hey everyone so I made a U-turn and lock the wheel all the way and as soon as I did that now im having a noise coming from the driver front. Its sound like a muffler/rattling noise. I hear it when accelerating or sometimes when im not moving, I check the front end everything is good except I noticed wear and tear from the control arm bushing other that that the struts need to be replaced. Please help!
Old Dec 2, 2021 | 08:45 PM
Noise when not moving? Rattling exhaust heat shield? Brake rotor splash shield messed up?
Old Dec 3, 2021 | 01:00 AM
ToneCap0ne's Avatar
ToneCap0ne
Everything intact, brand new brakes and rotors all around. As you first accelerate, you feel a loud rumbling noise
Old Dec 3, 2021 | 06:14 AM
pmesfun's Avatar
pmesfun
Check your wheel lug nuts.
Old Dec 3, 2021 | 10:58 AM
Aus430's Avatar
Aus430
When it happens to the noise when you aren't moving in gear? what happens if you put gearshift in park?
Does the noise stop when engine is switched off?
When you hear it (and when stopped) if you get out of the car to listen, can you hear it then? If so where does it appear to be coming from?
What about with the hood up? Is it eminating from anywhere in particular?
Old Dec 4, 2021 | 08:42 AM
ToneCap0ne's Avatar
ToneCap0ne
Only make the noise in drive all the other gears no noise. When ever I go up and down bumps the noises goes in and out according to the dip of the wave. Idk if that helps
Old Dec 6, 2021 | 01:49 AM
BigBoomer's Avatar
BigBoomer
Sounds like it may be the suspension compressor as that is in that part of the car.
Other than that I can't think of anything that could rattle whilst the car is stationary.
Old Dec 8, 2021 | 12:50 PM
ToneCap0ne's Avatar
ToneCap0ne
It's not air suspension, no compressor
Old Dec 9, 2021 | 02:20 AM
BigBoomer's Avatar
BigBoomer
If it's intermittent but only happens when the engine is running (whether moving or not) then it must be one of the items driven by the belts.
Since it started with you going full lock, it'll probably be the power steering pump.
The next time it makes the noise when stationary, pop the hood and see if you can localise it.
David2gs
Mar 9, 2015 10:52 PM
lexusls4
Dec 5, 2013 07:44 AM
Luin
Mar 22, 2007 08:14 AM
tommy420
Maintenance
Mar 8, 2005 09:25 PM
