Slow to Shift Into 6th
Old Sep 28, 2021 | 09:37 AM
BaconLS430's Avatar
BaconLS430
Default Slow to Shift Into 6th
On my 2006 LS430, in the past month or two, it's developed an issue where when I first start and drive it after it's had a chance to cool, it takes longer than usual to shift into 6th. It seems be temperature dependent, with cooler weather taking it longer driving to shift. This may be normal but I don't remember my mom's 2005 doing this and I also don't remember it doing this when I purchased the car in February and drove it in much cooler weather. Shifting between 1-5 is normal and once it does shift into 6th, it's a smooth and normal shift. Transmission does not slip or shift hard.
Based on service records and fluid conditions, it had the original transmission fluid in it until I serviced it last week. A pan drain and fill did not better or worsen the shifting.
Has anyone else experienced this? If so, is it normal or a problem?
Old Oct 18, 2021 | 08:52 PM
BaconLS430's Avatar
BaconLS430
Has anyone else had this happen with their car?
Old Oct 19, 2021 | 04:03 AM
TominPT's Avatar
TominPT
If you only did one pan drain and fill you still have most of the original transmission fluid in there. Three or more are needed to substantially replace the old with new. There is a post on here with the percentages of old v new for different numbers of drain/fill, may be in the "mother thread". What color was the fluid that came out and how many miles on the car?
Old Oct 19, 2021 | 07:28 PM
BaconLS430's Avatar
BaconLS430
Car had 178,796 at time of service, fluid was brown but free of grit and other debris, felt like good viscosity and lubricity, and didn't smell burned. Transmission doesn't slip or have any difficulty shifting through the first 5 gears, and once it finally goes into 6th that first time, it's business as usual.
I really think it's related to fluid temp/viscosity. I had a Sebring that behaved similarly in cold weather and wouldn't shift past 2nd gear until the trans fluid achieved operating temperature.
jmsmiff
Mar 25, 2020 02:34 PM
nodeal
Dec 21, 2018 03:40 PM
rselby
IS F (2008-2014)
28
Nov 18, 2016 03:53 PM
outlaws
Jul 3, 2009 07:33 AM
Ag02M5
Performance
Dec 6, 2002 03:47 PM
