Is this paper clip fix time?
Old Jun 4, 2021 | 12:14 PM
Bocatrip's Avatar
Bocatrip
Default Is this paper clip fix time?
I recently got my CEL on for my PO440 which I've had for years. After erasing the codes with my OBD reader, the CEL was off and I went on my way. Later in the day, I went on the highway and I got the Check engine light, VSC off, and Red Triangle. When I hooked up my OBD reader is showed 3 codes found. When I went to read them, it said NO DTCs can be found. I again erased the codes and the CEL was off as well as the VSC off. Should I be waiting for the eventual return of the CEL, and VSC off light to come back on? If so.... is this once again the paper clip fix? (which I have done a number of times in the past) I assume is it not the fuse for the OBD outlet plug.. Thanks all.
Old Jun 4, 2021 | 04:18 PM
Scan it with a dealer level tool to see what it's complaining about
Old Jun 5, 2021 | 08:52 AM
Bocatrip's Avatar
Bocatrip
Thanks...I'll give that a try when it comes back on.
rfopt
12
Jul 30, 2019 12:58 AM
DAbernathy
GX - 1st Gen (2003-2009)
Jul 14, 2019 04:13 PM
byrnech
Aug 17, 2013 02:58 PM
audphile1
Apr 9, 2009 09:10 PM
Lunchbox
Maintenance
Aug 1, 2007 09:37 PM
