What do stock wipers look like?
Old Nov 25, 2020 | 06:25 PM
Default What do stock wipers look like?
I had a wiper fail today and tear at the last 2 inches, I think I have OE blades still and would like to just buy the inserts but I'm unsure what I have is actually the stock assembly. Does anyone have a picture of the stock ones?
Old Nov 25, 2020 | 06:56 PM
bradland's Avatar
bradland
Pull the rubber out, if there’s a long thin stainless strip inside they are Toyota/Lexus. When you buy rubber inserts the metal strip gets re used.
Edit- I guess most brands probably use a metal strip inside the rubber
On Toyota wipers it’s visible on the side.
Old Nov 26, 2020 | 06:00 AM
Ah dang it, guess I'm ordering the whole blade. Thanks bradland
Old Nov 26, 2020 | 07:16 AM
marsmango's Avatar
marsmango
You can also purchase the NWB blades and OEM Lexus inserts. Much cheaper than buying the entire OEM blade. I did this recently and they work perfectly https://www.clublexus.com/forums/ls-...l#post10022388
JumpinJohn
Nov 25, 2020 06:03 PM
zapa
IS F (2008-2014)
28
Sep 19, 2015 01:57 PM
JVT
Jul 11, 2009 03:48 AM
