Wheels
Old Feb 11, 2020 | 02:52 PM
Alx430's Avatar
Alx430
Default Wheels
I want to put 19s on my car but want 11s in the rear wat fitment can I use
Old Feb 11, 2020 | 02:57 PM
Blaque Diamond Wheels's Avatar
Former Sponsor
You can run a 19x9 / 19x10.5 set up on that car, but I am not sure about an 11" as we have personally not done that fitment on this model.
Old Feb 12, 2020 | 01:41 PM
onthelo's Avatar
onthelo
Just a question why 11" and not go with 10.5" … 10.5" is a much more manageable rear wheel to fit but even then will need quarter panel work or suspension arms
Old Feb 12, 2020 | 01:45 PM
Alx430's Avatar
Alx430
with what offset +/- 0 idk this is my first ls430 that's why I'm asking ordered full one piece megan struts
Old Feb 12, 2020 | 02:50 PM
Former Sponsor
For the rears, we tend to stick around the 38-42 range.
Old Feb 12, 2020 | 03:56 PM
Chucky1's Avatar
Chucky1
With that offset range, does that keep it tucked under the fender? I am no good at all figuring offsets.
Old Feb 13, 2020 | 08:09 AM
Tostada's Avatar
Tostada
Check this site:
https://www.customwheeloffset.com/wh...S430&sort=date
Also, do some research on previous posts. I've personally have found quite a lot of info on older threads regarding this topic
Old Feb 13, 2020 | 08:12 AM
Former Sponsor
Typically, we try to have the wheel sitting flush with the fender when picking offsets.
Old Feb 15, 2020 | 08:50 PM
Duck05's Avatar
Duck05
Seems very extreme for an LS430. What is your total desired setup with tires are you targeting? Besides fender/wheel well clearance you need to assess brake caliper fit, likely hub rings, and other fun factors. Keep us posted and as always pictures are a must....
Kurmaz
Performance
Aug 12, 2020 09:14 PM
PhiGam27
Feb 17, 2014 08:56 PM
lexus95
Aug 5, 2010 08:38 AM
Rock-a-Lex
Performance
Apr 15, 2009 12:22 AM
radicalrev
Nov 18, 2007 02:18 PM
