Re-searching for a 430
Old Jan 8, 2020 | 05:39 PM
  #106
SGS3's Avatar
SGS3
Originally Posted by Bocatrip
Are you talking about for the "soft close" on an UL?
Oh no just the keyless entry function
Old Jan 8, 2020 | 06:39 PM
  #107
Takes about 30 min a side going slow and parts are $1050 each side if you want OE ones
Old Jan 8, 2020 | 09:13 PM
  #108
SGS3's Avatar
SGS3
$1050??? How come it's that expensive?
Old Jan 8, 2020 | 09:45 PM
  #109
Because honestly all the parts for these cars are very expensive. Freaking headlights are $400 and OE parts are triple what a high end domestic car will run you, I knew this going in but still.
Old Jan 9, 2020 | 04:33 AM
  #110
Peacebay's Avatar
Peacebay
Yeah I just added an E60 5 series to my stable yesterday (got it for a deal I couldn't pass up) and I'm pleasantly surprised how affordable even the OE parts are compared to our Japanese boats. I mean stuff also breaks more on the Bimmers, so.. Love the car though. Totally different animal than the LS
Old Jan 9, 2020 | 05:09 AM
  #111
Wheelyneat's Avatar
Wheelyneat
I did my driver’s door actuator and I guess I’m pretty slow - took me about two hours. Steep learning curve so the next one should be quicker 😉. You might want to do what I did and check with ActuatorsPlus. He rebuilds and guarantees his actuators for a fraction of new OEM cost. It worked for me 👍
Old Jan 9, 2020 | 06:31 AM
  #112
Johnhav430's Avatar
Johnhav430
It's such a myth that German cars are expensive for parts, and Japanese and American are cheap. My wife's GM, it's alternator is made in USA by Denso and around $600.
With German again I love the transparency where this part is OE in a BMW box. This part is the same, OEM, in a Continental box. Up to you which you want.
Look up a ABS sensor, a BMW 7 is like $100 for OE. A LS430 is almost $400. Look up a brake wear sensor wire, maybe $35 v. $130. To me, it's the business model. Like a cheap laser printer whose toner costs a fortune, that's how revenue is made under one model. Lexus is that. I mean the car had 5k factory recommended service!
Old Jan 9, 2020 | 07:23 AM
  #113
Sure, but the BMW will constantly break and annoy or cost a hell of a lot more in labor. Speaking of there is a 7 series at my shop right now with a no start and can bus failure, needs a new anti-theft ECU and has a sea of other small problems too. About 100k less miles than my car too
Old Jan 9, 2020 | 12:53 PM
  #114
SGS3's Avatar
SGS3
I guess you talk about the whole unit. I'm looking at these tutorials and while it looks complicated, probably doable.
https://www.clublexus.com/forums/ls-...-tutorial.html
https://www.clublexus.com/forums/ls-...or-repair.html
Old Jan 9, 2020 | 01:05 PM
  #115
Bocatrip's Avatar
Bocatrip
Yes, the small motor is 5 bucks, but care must be taken with taking apart the old actuator and placing the new motor in SECURELY so that there are no additional issues with noise or operation. You do save money on the parts. Still requires a degree of labor and carefully placing all the screws and bolts where they belong. Doable, and cost effective if doing it yourself. Most importantly....take your time.
Old Jan 9, 2020 | 07:09 PM
  #116
Be ready to buy rebuilt units if you break something in there too, it's quite fragile
Old Jan 9, 2020 | 10:14 PM
  #117
430SLOwner's Avatar
430SLOwner
Maybe this may help?
Old Feb 7, 2020 | 05:04 PM
  #118
Andy430's Avatar
Andy430
Default LS mechanical problem
Can anyone help me with a crank but no start issue with my LS?
Old Feb 7, 2020 | 08:51 PM
  #119
BMW7_LS430's Avatar
BMW7_LS430
Have you done the battery test? If not, do that first.
I just ended up replacing my battery in less than 2 years and the previous one needed to be replaced in less than 2 years too. Short drives. I am going to put this one on trickle charger now.
Old Feb 8, 2020 | 10:31 AM
  #120
Bocatrip's Avatar
Bocatrip
Yes, short drives can shorten battery life. I'm probably lucky to get closer to 3 years out of my last 3 batteries. I've seen my alternator putting out 13.4 volts occasionally which is not optimum I already have my battery set up for a CTEK battery maintainer, but since I drive daily, I don't bother using it. I just know that when I get close to 2 1/2 years of battery usage it will be time for replacement soon.
Dave144239
Jan 4, 2019 07:02 AM
MozartMan
May 18, 2018 08:34 PM
dcasanares
Mar 1, 2017 09:07 AM
dmmoroney
Aug 4, 2016 06:09 PM
tjschraf
May 15, 2012 02:00 PM
