03 LS430 - Hard starting with whining noise
Old Dec 10, 2018 | 07:10 AM
Arcturus's Avatar
Arcturus
Default 03 LS430 - Hard starting with whining noise
Today my LS430 had a lot of trouble starting. The starter sounded like it was turning but it was making an odd whining / humming / oscillating noise. It took multiple prolonged cranks to get the car going. After it finally fired up the car drive great and there were no more issues starting. The battery is new (1 year old).However, I’ve been hearing clunking sounds after the car starts lately. Is my starter dying a snow death or could it be something else?
Old Dec 10, 2018 | 01:14 PM
911LE's Avatar
911LE
Do a current draw test to see if the starter is failing. It could also be your battery, cable corrosion, loose connection, etc. If it is the starter you will know very soon as they usually work or they don't.
Old Dec 11, 2018 | 07:34 PM
Arcturus's Avatar
Arcturus
How do I do a current draw test? The battery’s new and I never had a problem with cranking. It sounded like it was free wheeling but not turning the flywheel. Maybe solenoid?
Old Dec 11, 2018 | 08:23 PM
caddylover's Avatar
caddylover
hope it ain't the starter. it's tucked into the engine. PITA to get to.
Old Dec 12, 2018 | 07:38 AM
05ls430518's Avatar
05ls430518
You only have to take the intake manifold off its a 1 hour job to change the starter.
Old Dec 12, 2018 | 08:16 AM
caddylover's Avatar
caddylover
good to know, but if it was anything like the wife's Sequoia, i had to pull a bunch of **** off and out to get the starter out. All in all, it's not a bad place to have a starter since it's out of the elements.
Old Dec 13, 2018 | 04:36 AM
430's Avatar
430
The starter in the LS400 is deep within the engine and very difficult to get to. The location in the the LS430 is much easier. You might want to go to an auto parts store (Advance Auto, Auto Zone or even O'Reilly's, etc) that perform a free electrical test. It just takes a few minutes.
Old Dec 13, 2018 | 10:25 AM
bradland's Avatar
bradland
400 and 430 starters are in the exact same location.
wpace101
Dec 24, 2024 03:53 AM
Liybzd
Jun 27, 2019 09:47 AM
joes98gs
May 11, 2019 07:32 PM
poplinux
Aug 25, 2015 06:15 AM
wckd2022
RX - 1st Gen (1999-2003)
Jul 6, 2005 06:09 PM
