Need help - 2006 ls430 ecu location?
Sending ECU for rebuild due to known hard downshift issue. Have seen conflicting info regarding ECU location for removal in my 2006 LS430. Can anyone confirm ECU location for my model? Thanks!
There are over 40 ECU's on the LS430. Attached are the pages, from the factory repair manual, showing the locations of various ECU's. For transmission shift, I suspect you're looking for the ECM (Engine Control Module). The ECM is located in the engine bay.
It's right behind the driver side headlight. There are 3 10mm bolts to take the cover off and just unplug and ship it out. I had to deal with this in June, sent it to SIA Electronics and they had it back to me in under a week.
After getting my car back from the dealer after the flashed the ECM, it fixed all those problems for me and drove like a different car (in a good way).
It is not the reflash, that TSB was onlyfor 04 models and early 05. Mine was from March 2005, so the reflash would not have done anything. I took it to the dealership and the were sure I needed to have my transmission rebuilt, they said there is no way it is the computer.
I was experiencing a harsh downshift from 3-2 then a violent downshift from 2-1.
This thread has some info on it, most recently post #36 to the end: https://www.clublexus.com/forums/ls-...1st-2nd-3.html
Also on here someone chimed in with their experience, 3rd post down: https://repairpal.com/poor-shift-qua...low-speeds-550
Here is the website for SIA http://siaelec.com/
It fixed my problem, I was shocked when I popped the ECM back in and everything was smooth as butter.
My 04 LS430 UL has gotten this virus where I initially had the check eng light with a vcs on and a hard shift from 3rd to 2nd and really hard from 2nd to 1st. Indie found up lock up solenoid stuck and replaced. Ran fine for a day and its back to hard shifting and with no lights.
So I've sent the ecu off to SIA and waiting for the return.
However I was curious about this "Technical Service Bulletin dated Dec 6, 2004" and is this possibly what SIA might be doing or at least incorporating?
Got my ECU back today and it happens to be the rainiest day in months. But I do persist and went for a short drive and "EUREKA". Shifts as smooth as butter.
Thanks to all those who pointed in this direction. SIA rules. Get the deal on ebay, its only $135 as opposed to on their on web site, its listed as a $180 job.
Praise be...
Praise be...
Sorry your having some problems finding it. I simply went on Ebay and typed in SIA ECU repair, and its even cheaper then before. $115.
https://tinyurl.com/6rxhhjr
Good luck, Car still runs better then when I bought it somehow.
