engine misfire
Old May 28, 2018 | 05:36 PM
aljazey's Avatar
aljazey
Default engine misfire
I have a 2002 lexus ls430 UL with 160000 miles on it. I religiously have my car maintained to the highest level. Most of the highly sophisticated work is done by the Lexus Dealer. the rest is done by a great mechanic shop. I haven't driven on long trips on the freeway for some time. A couple of weeks ago, I kicked the gas pedal down in order to go into passing gear. the engine sputtered at 6000 rpm and didn't want to shift into the next higher gear. I tried this 2 more times and I felt some improvement.. I purchased some very high end injector cleaner. after a tankful of gas was consumed, I tried it again. considerable improvement, but not quite a clear shift. I am thinking maybe the plug wires or MAF might be the problem. Your thoughts please.
Old May 28, 2018 | 07:08 PM
ls430w140's Avatar
ls430w140
Check the connector which goes into camshaft sensor. Do you recall by any chance any previous dtc codes related to igniter, engine control system, or air/fuel intake?
Old May 29, 2018 | 08:36 AM
caverman's Avatar
caverman
Do you have a check engine light?
Old May 29, 2018 | 09:31 AM
aufenscuht's Avatar
aufenscuht
Pull all of your coils and inspect for cracks in the boot casing. I bought my LS w/ 186,000 two weeks ago and am eliminating all issues or what can become potential issues. I discovered that all left bank coil packs were starting to get hairline cracks in them. You may have one potentially exposed, causing an intermittent issue under load.
Old Jun 4, 2018 | 10:36 AM
aljazey's Avatar
aljazey
Smile Engine misfire.
Thanks very much for your responses. Because of your info, my local mechanic will be checking and confirming the problem based on your help.
Really appreciated.
Old Jun 4, 2018 | 10:40 AM
aufenscuht's Avatar
aufenscuht
Please make sure Joe **** the rag man does not work on it!
Old Jun 4, 2018 | 07:58 PM
Jabberwock's Avatar
Jabberwock
Have your tech see if any codes are being written by the engine ECU. Just guessing here but maybe there is an issue with one of the camshaft position actuator valves which would show up under load/high rpm. These have been known to fail or go bad after 100k miles on some LS. There is one per bank on the engine, fortunately they are pretty easy to replace.
Joshlee73
Jul 29, 2020 12:23 AM
sm0kescree
Nov 21, 2013 08:25 AM
lq4chevell
Feb 4, 2012 01:00 PM
Leeladisky
Jul 29, 2003 02:24 PM
