Center console lights sometimes go out
Old Apr 24, 2019 | 05:30 AM
  #31
jls667's Avatar
jls667
Two weeks ago I changed the day/night sensor for the nav screen. It worked until today. The screen stays in day mode. Since the problem started suddenly I suspect a fuse. Does anyone know which fuse controls the day/night function and illuminates the green bulbs behind the buttons like the hazzard, map, VSC, radio, etc?
Old Apr 26, 2019 | 08:21 AM
  #32
jls667's Avatar
jls667
Now the lights are suddenly working again. I did not do anything. How do you fix an intermittent problem?
Old Jun 3, 2019 | 09:11 PM
  #33
q8delta's Avatar
q8delta
hi, how did you attached The day/night sensor, I removed the nav screen and I couldn't reach it
Old Jun 10, 2019 | 10:19 AM
  #34
jls667's Avatar
jls667
I basically broke off the sensor by pulling on it. I found the wire behind the NAV. Since I could not reach the hole, i had to put through a snake from the top of the dash. Once I got the wire up through the hole, I attached the new sensor. Even with the new sensor, the day/night changeover is unreliable. There must still be a problem. Maybe there is a bad relay somewhere.
Old Jun 11, 2019 | 06:41 AM
  #35
NetG's Avatar
NetG
not trying to be an ***, but remember, the dash lights up during the day but at night the car senses the drop in luminocity and will dim the lights. If you have the dimmer switch set to a low setting it will light during the day and shut off at night. Had this happen on my current 430 and my 400, thought my dash was screwed up...so before someone tears into it, turn the **** clockwise a bit just to make sure that's not it
Old Jun 11, 2019 | 10:23 AM
  #36
Bsavage's Avatar
Bsavage
Is it weird that that **** is for some chime volume but when I turn it there’s no affect what so ever and the signal for my key fob gets weaker , I’m going to see if it effects the lights
Old Jun 28, 2019 | 11:16 AM
  #37
jls667's Avatar
jls667
I still have not figured out why my center console lights go out sometimes. I thought replacing the dash day/night sensor would have fixed the issue. It didn’t. Maybe there is an unreliable relay somewhere. Any ideas?
Thank you.
Old Jun 29, 2019 | 08:44 AM
  #38
jonathanz's Avatar
jonathanz
Thank you.
read my post #16.
Old Jun 29, 2019 | 11:13 AM
  #39
jls667's Avatar
jls667
Please be more specific. I have a feeling you are on the right track. What is a JB on the driver’s side?
Old Jun 29, 2019 | 06:16 PM
  #40
jonathanz's Avatar
jonathanz
the fuse box on driver side left foot wall. the JB has relay control the lighting....
edit: actually, next time when you're driving at night and screen is bright, kick the fuse box.
Old Jun 30, 2019 | 05:22 PM
  #41
jls667's Avatar
jls667
Did you actually look this up on a wiring diagram? I see there are two relays. One is listed as accessory and the other is ignition.
Old Jun 30, 2019 | 07:32 PM
  #42
jls667's Avatar
jls667
Wow! I am almost positive you are correct. When I bang my foot against the fuse box, the display changes from day to night. The relays are hidden out of site. Is there a trick to remove the carpet around the fuse box to expose the relays?
Old Jul 1, 2019 | 06:08 AM
  #43
jonathanz's Avatar
jonathanz
you'll have to take your time and work around it. BUT the good news is you know there's a temp fix "just kick it" switch.
even if you purchase another JB from junk yard, you wont' know if that one have issue or not.
Old Jul 1, 2019 | 07:54 AM
  #44
jls667's Avatar
jls667
Do you have the wiring diagram for the relays by the fuse box?
Old Jul 1, 2019 | 07:39 PM
  #45
jonathanz's Avatar
jonathanz
no i do not but share if you located.
