Adding back up camera to double DIN stereo?
Old May 15, 2018 | 10:25 AM
Romanova's Avatar
Romanova
Default Adding back up camera to double DIN stereo?
I've searched and searched and came up empty handed. Has anyone added a backup camera to their aftermarket double DIN system? If so;
1) What camera did you choose?
2) Were you able to mount it flush to the trunk garnish?
3) How did you run the camera wire through the trunk... was there an existing hole, or did you have to drill one?
Thanks!
Old May 15, 2018 | 02:47 PM
sha4000's Avatar
sha4000
A simple Google search brought up this....
​​​​​​https://www.clublexus.com/forums/ls-...nd-part-s.html
Old May 17, 2018 | 06:39 AM
gmoney94's Avatar
gmoney94
I have an aftermarket 2DIN head unit (Alpine ILX-107) and it's connected to a backup camera as well (Rydeen CM-DUO Mini Backup Camera w/ Night Vision), Best Buy did the installation for me so I can't speak to the specifics, but the camera works well - quite clear and the night time performance is very solid. I'll post pics of the head unit and the camera.
Old May 17, 2018 | 05:58 PM
LS430inDE.'s Avatar
LS430inDE.
Did you pick that specific camera out or was it part of the package? (side note---you should have scrambled out the Dallas Cowboys license plate frame instead of your plate! )
Old May 27, 2018 | 03:43 AM
rkw77080's Avatar
rkw77080
Please beware that the wire colors for the backup lights on the 2001-2003 and 2004-2006 are different (see electrical schematic). Also please refer to the attached PDF for termination location information.
File Type: pdf
Old May 27, 2018 | 08:48 AM
Romanova's Avatar
Romanova
Thank you rkw77080 for posting this. I'm waiting on one more piece and then I will document the process of installing a backup camera on a non-nav LS430.
Old May 29, 2018 | 11:04 AM
gmoney94's Avatar
gmoney94
I picked (not part of a package) a highly rated, but reasonable, cam. It's very sharp - almost OEM quality, and the night performance is very respectable.
Go Cowboys!
Old May 30, 2018 | 07:46 AM
3GS404's Avatar
3GS404
plz keep us posted ! Im interested:-) thanks
Old May 30, 2018 | 12:54 PM
e60bmw's Avatar
e60bmw
I used the pioneer one that came with my headunit. I posted in a thread a few months back about the process. On my car there was a little plastic piece where I guess a factory camera would go, so I drilled a whole thru it and mounted it there. Honestly the camera is kinda junk, the camera on my GS is way better. Do you currently already have a double din in place?
Edit: Found the thread https://www.clublexus.com/forums/ls-...install-5.html
It was difficult to fish the wires thru with the UL, I basically had to remove most of the back of my interior.
Old Jun 1, 2018 | 02:28 PM
rkw77080's Avatar
rkw77080
Old Jan 7, 2019 | 07:42 AM
Matt19810's Avatar
Matt19810
What site are you using to find the harness diagram??
python
13
Sep 25, 2015 06:21 AM
James4394
IS - 1st Gen (2001-2005)
13
Feb 15, 2015 03:03 PM
SteveMason
CT 200h Model (2011-2017)
Dec 1, 2014 11:59 AM
GChau87
Feb 5, 2014 07:39 PM
dudeman
Hybrid Technology
May 10, 2008 10:19 PM
