Alternator Replacement 2005 Denso
Wife called me and said she was stranded because Lexus wouldnt start. Got a jump start and car made it 10 miles home before quitting in the driveway dead as a doornail.
Turns out the alternator was not charging and discharged the 5 year old Optima yellow top to empty. These cars are smart in that they shut off the radio, hvac and lights to conserve charge when issue like this happens to limp home.
Ordered Denso replacement from Amazon for 250.00 and got a new Optima Red Top to do the job at home.
The whole thing can be done with a 10mm, 12mm and 14mm socket set. Disconnect battery, remove drive belt, jack car up and remove undertray. Once you are underneath you have access to 3 nuts/bolts that hold it on and unplug the harness on the rear.
My car is a 2005 with 116k miles. We got lucky and didnt have to get towed but for other members who have 100k or more miles on the original one, I would replace it before it dies and leaves you stranded somewhere. Its a good piece of mind job that can be completed in less than 2 hours.
There is another thread where people are posting who are on the original alternator. OP there did not want failures to be posted (Here is the link). let's use this thread to post if your alternator failed and at what miles?
2004 LS430 - Alternator failed at 90K miles - Replaced with Autozone version
Fortunately my failure was discovered by my family with car in the garage during my business trip. No towing was required. I needed to get it running quickly. I just got one from Autozone and it has been fine now at 113K miles.
I do not believe failure is common therefore replacing it as maintenance item may not be a good idea.
There is another thread where people are posting who are on the original alternator. OP there did not want failures to be posted (Here sit he link). let's use this thread to post if your alternator failed and at what miles?
Amazon price - $243.32
Rockauto price - $125.79
Maybe Amazon Prime had it on your doorstep the next morning, which is worth something, but is it worth the price of (almost) 2 alternators....?
There might be more to the story. Maybe that $250 includes the core charge which is an additional $68 on the Rockauto price. Amazon does post different prices on the same item to different people based on your web viewing habits...
I'm on vacation starting Tuesday, so I'll be starting it Thursday morning and should finish late afternoon.. I'll be taking photos..
sweet...this failed on my wife's SUV last Sat. Rapidly....howl/whine started Friday, by Sat. evening, car went into battery saver mode. We had the extended warranty but I looked up the job and it's about $1,000, for a GM vehicle. Look at the procedure and yes, a/c lines, p/s lines, etc. Nice to know the LS is easy. GM part is also made by Denso, and lists for $678...
p.s. why her car needs a voltmeter is beyond me, but high voltage (and it is intelligent where it drops it when not needed) seems to indicate trouble. Battery going bad, volts high. Alt fail, batt is good, and volts high. Now it seems to be 14.25 most of the time, and even drops down to 13.x implying battery is full. When bad 16v+...
I just sold a 2006 LS430 at my job with 216k and owner said he had his alternator fail at 180k and leave him on side of the road.
