Beeps coming from control panel
After searching and searching I feel like maybe only one person has had this problem with no answer to their thread. I am hoping someone can help. As im driving my car keeps beeping two times about every 3 minutes. It is the same beep sound that you hear when you push the map, ac, audio or option button however I am not pushing any buttons. Sometimes when I hear the beeps those buttons will not work, meaning I will hit climate when looking at the map and my climate control will not pop up. This just started happening and I am hoping it is an easy fix or reset.
Forum Administrator
Sounds to me like one of those buttons is sticking. Try pressing every single one of the buttons around the navigation and see if anything feels like it doesn't clearly depress and return
DPK*David (09-08-17)
Hello,
thank you for that as I did not think to check that, however I did just go check and none of them appear to be stuck or sticking. Also I forgot to mention, the one thread I could find where someone had the same issue with no replies, he mentioned that when he turns his steering wheel to the left or right the buttons will begin to work. I went to try this and mine is doing the same.
Just wild &^% guessing but your intermittent button failure may be related to a clock spring failure in the steering column. Search "clockspring" and you will find some info from previous posts.
https://www.clublexus.com/forums/ls-...ing-wheel.html
DPK*David (09-11-17)
I have a quick beeping sound problem, but I only notice it when the stereo is on while I’m driving. It beeps probably 2 times per minute.
thank you. my beeping problem is now fixed. Like I said before, my tires were inflated to about 33 psi. Yesterday I filled them up to 38 psi, and now there is no more beeping. Yay
Once that is reset it will learn the new pressures over the next 60 miles.
I can't think of anything else that would cause a beep to stop by increasing the tyre pressure.
Lexicon1
SC- 1st Gen (1992-2000)
08-07-09 04:28 PM
