Power steering pump -whining
Old Mar 29, 2017 | 07:21 AM
Tmhender82's Avatar
Tmhender82
Default Power steering pump -whining
Need advice please.
My power steering pump has started whining, but it is not low on fluid. Do I need to replace the entire pump, or should I just start by replacing the filter?
Thanks for your help!
Old Mar 29, 2017 | 08:46 AM
Bocatrip's Avatar
Bocatrip
Originally Posted by Tmhender82
Need advice please.
. I don't know where you live or if it's cold there. Does the pump whine noticeably even after the car is totally warmed up? I live in the Southeast but when there are cold mornings my pump will whine but quiets down when car warms up. I've lived with it for 7 years. If yours is consistent I'd investigate further. Whining pumps for our cars is common. You don't want a leaking one!
Old Mar 29, 2017 | 03:44 PM
rkw77080's Avatar
rkw77080
Often time, low fluid level is the primary cause for whining.
In my case, the power steering reservoir is permanently stained so looking from the outside, it looks full. But when I opened the cap and looked at the little plastic dip stick, it showed low level. Actually my fluid level was so low that it was foaming/bubbling.
I'm hoping that your situation is the same as mine, in which case, just top off the fluid and problem solved!
Old Mar 29, 2017 | 04:24 PM
Bocatrip's Avatar
Bocatrip
Yes it's true that the reservoir on most of these old cars are stained and you cannot see the level unless you remove the dip stick...however if you find that it is low on fluid and topping it up eliminates the noise are you eliminating the problem? Power steering most likely is leaking somewhere and should be investigated.
Old Mar 29, 2017 | 05:06 PM
rkw77080's Avatar
rkw77080
Good point, Bocatrip. That will take care of the symptom, but not cure the cause. Addressing the leak will require crawling under the car to look for wet spots.
Old Mar 29, 2017 | 05:26 PM
Bocatrip's Avatar
Bocatrip
Power steering most likely is leaking somewhere and should be investigated. This most likely will be the cause...
Old Mar 31, 2017 | 03:58 PM
tallcaguy's Avatar
tallcaguy
Can you hear the whine in the car when stopped? When driving? Mine starts at 1,500 and gets worse. I usually drive 75-80 mph (around 2,200). It's just noticeable enough to be irritating. If I slow down from 80, it gets momentarily louder. Per an old post about 04's in 6th gear whining specifically at 75-80, I shifted into 5. Didn't make any difference. I shut off the heat (no blower fan) but didn't make any difference. I tried coasting at speed (wheel bearing?) but no noise. The local shop was supposed to just change the PS fluid but they did a flush and fill (without my permission). No change. Not a fan of flushing fluids on older cars. Noise (at idle) does increase with steering wheel movement. That's the classic signal that the pump is wearing out. I'm ready to just replace the pump w/ new OEM. Suggests appreciated!
Old Mar 31, 2017 | 04:40 PM
JffGRY706's Avatar
JffGRY706
do you use Power steering fluid or automatic transmission fluid?
Old Mar 31, 2017 | 05:26 PM
rkw77080's Avatar
rkw77080
You can use ATF DEXRON® II or III
Old Mar 31, 2017 | 06:18 PM
Lzam's Avatar
Lzam
Mine is a 04 and makes the same noise but there is no leak or anything car runs fine just makes the whine noise through out the powerband.
Old Mar 31, 2017 | 07:59 PM
warminwisc's Avatar
warminwisc
Suck some out add Lucas power steering leak stuff. Worked for me.
Old Apr 1, 2017 | 05:25 PM
911LE's Avatar
911LE
Mine whines when the fluid is cold. After a few minutes of driving it goes away. When I had my pump off of my engine I did notice a lot of axial play in the shaft. I didn't know if it was normal but it seemed excessive to me. It still works fine so I will hold off on replacing it.
Old Apr 1, 2017 | 10:36 PM
tallcaguy's Avatar
tallcaguy
am going to try rkw's ATF DEXRON® II or III suggest and see what happens.
Old Apr 3, 2017 | 03:20 AM
XJSFan's Avatar
XJSFan
I decided to go with Redline synthetic Power Steering fluid a few years ago and have not had any issues or sounds coming from my power steering... It seems to really work well and the reservoir looks almost like new.
Old Feb 3, 2026 | 12:37 AM
hsmac's Avatar
hsmac
Why are some people saying the pump should be changed from the top? I’d prefer to not have to remove the wheel but it’s seems logical to do so.
Daspyda
Sep 24, 2015 01:56 PM
mlacomb
Apr 8, 2013 05:00 AM
worldforgo
Feb 4, 2012 09:47 PM
dubstar
IS - 1st Gen (2001-2005)
Jun 17, 2011 04:29 PM
billj747
16
Jan 21, 2008 10:53 AM
