navigation dvd reader
Old Oct 4, 2016 | 08:23 AM
johnnylt's Avatar
johnnylt
Default navigation dvd reader
Hello ,does anybody know if there is a fuse for the dvd reader in the trunk for the navigation ? if so where is it located please ? also if the reader is dead how can you eject the disk
Old Oct 4, 2016 | 08:35 AM
Johnhav430's Avatar
Johnhav430
I know that there are fuse boxes to the left of the driver, and the right of the passenger (I'm new and I had to find the fuse for the cigarette lighter socket in the ash try, which was on the pass side).
I was in the trunk yesterday replacing the DVD, so I can say for whatever reason, that unit is difficult to maneuver, so be careful to not scratch up the DVD...I didn't get the unit totally free so it was at an angle...
Old Oct 4, 2016 | 08:40 AM
johnnylt's Avatar
johnnylt
I did manage to get it out ,you have to tilt it up then pull it out ,but my issue I couldn't eject the disk . before I replace this dvd reader im just trying to figure out if there is a fuse for it ? otherwise a new one wont work either
Old Oct 4, 2016 | 08:48 AM
Johnhav430's Avatar
Johnhav430
Curious....what do you see on your dash if the reader is not powered.....I see no difference after the disc update but I knew going into it, it wasn't as if the screen would change....
Well, if you do get it working, seems that 2016 discs are available on eBay for $13.....worked for me....the one I took out said 2004 maps, as if it were a 2005 disc, my car was mfg 10/05.....good luck.
Old Oct 4, 2016 | 08:53 AM
johnnylt's Avatar
johnnylt
My screen is showing external device not connected , like theres no power ? that's why I wonder if there is a fuse before I replace the whole unit
Old Oct 4, 2016 | 08:57 AM
Tom57's Avatar
Tom57
Don't replace the whole DVD player until you verify there's power to the wire harness connector at the DVD player. There is a fuse. rkw may be able to post a pdf showing both the location of the junction box ("J/B") containing the specific fuse, as well as the location of the fuse within the J/B.
EDIT: You have two (2) current threads on this very same issue.
Old Oct 4, 2016 | 09:15 AM
johnnylt's Avatar
johnnylt
Thank you very much guys . I know theres a fuse marked tv but I think that's for the back up camera and that does work
Old Oct 4, 2016 | 10:14 AM
johnnylt's Avatar
johnnylt
I looked in the book fuse#36 passenger compartment says radio and navi and fuse#46 In trunk says radio /Tel so it has to be one of those need a flashlight and have to look in there if there blown
Old Oct 4, 2016 | 05:47 PM
rkw77080's Avatar
rkw77080
Please check the 7.5A fuse called "RR ACC" in the trunk, and the 7.5A fuse called "TEL" in the passenger fuse box.
Old Oct 5, 2016 | 05:08 AM
johnnylt's Avatar
johnnylt
Ok Thank you RKW both fuses and they are both good!! So I guess I will replace the DVD reader , I wish I could eject the disc from the old one thou . oh well thanks everybody for the help
Old Oct 6, 2016 | 05:08 AM
johnnylt's Avatar
johnnylt
ok got a rebuilt off Ebay took out the old one connected the new one bolted back in the trunk compartment started the car , booted up no problem , Bluetooth back on ,everything good ,back to normal ,took about 10-15 minutes.....
nor725
Mar 27, 2024 04:35 PM
Moose329
Dec 22, 2014 12:36 PM
DLgolfs
Jan 6, 2010 07:24 AM
scalum1994
Apr 8, 2009 06:18 PM
bozer
Jan 14, 2008 04:30 PM
