FLICKERING Head Lights - 2004 LS 430
Hi everyone,
I'm looking at a 2004 LS, and in the service history there is only one item I am unsure about;
"DESCRIPTION: DISTRIBUTOR/HDLIGHT/T. SGNL ~|~CS AFS LT FLICKERING HEADLIGHTS STILL WORK. ~|~TECHNICIAN CONFIRMED FLICKERING PERFORMED HEALTH CHECK - CODE FOR REAR HEADLIGHT HEIGHT CONTROL SENSOR MALFUNCTION. QUOTE $579 PLS TAX INSTALLED. ~|~CUSTOMER DECLINES REPAIR AT THIS TIME. NOTE AFS LIGHT WILL CONTINUE TO FLICKER BECAUSE THE SENSOR HAS MALFUNCTIONED."
Any thoughts on this?
Thanks!
Thanks!
There's a height control sensor on the left front and rear which activate the headlight aim (up / down) at start-up. The rear sensor is apparently not working. The part (#8940850060) lists retail at $332. Diagram and part number below. It's an easy DIY. Cheaper through Amazon > https://www.amazon.com/LEXUS-REAR-HE.../dp/B017O0IPFU
http://www.lexussouthatlantaparts.co...=height+sensor
http://www.lexussouthatlantaparts.co...940850060.html
Searching about this on google, I keep seeing mentions of issues with air suspension. That is not relevant to this issue correct? This is just the headlight leveler? Not sure if there's a correlation. Again, I am not very knowledgeable on cars.
If you can safely jack up and support the car, remove rear wheel, then it's a few bolts and a plug-in wire harness. And, if you install the sensor in exactly same location as the one removed, you won't have any adjustments to make.
This is the car: http://www.highlineimports.com/web/u...ania/26213317/
I submitted the credit app earlier today. They've had a few price drops, and just yesterday came from $9,500 down to $8,900.
I don't see any issues listed other than the headlight sensor (although I know that doesn't mean there ARE no more issues).
Clean Carfax / 1 Owner / Under 11K miles per year avg.
Seems to be in great shape. Has new tires.
I hope it's a great deal :-)
I think I could manage that repair by myself!
Just took the plunge! Put the deposit down, will be picking up the car this Saturday.
I'm glad I waited it out. I spent the past 4 months emailing the sales rep about this car. Got it for $8,900 when they originally listed it at $12,500.
Will post pics when I have it!
Wintercat
Oct 7, 2018 03:32 PM
