LS430 Auto leveling motor reinsert
Old Jul 12, 2016 | 10:01 AM
Jobbyson's Avatar
Jobbyson
Default LS430 Auto leveling motor reinsert
My 2003 LS430 while replaced the headlamp bulbs. I for want ever reason took out the auto leveling motor. Know when I reinsert it I can't get the little ball arm inserted into groove inside the headlight. Any help would be appreciated.
Old Jul 14, 2016 | 12:51 PM
Jobbyson's Avatar
Jobbyson
So nothing on this, I'm really stuck can't figure out how to get the little ball head back into the slotted groove. Sure dealer would do it for a cost but at $100+ an hour I may live with it. But really frustrating since other side still auto levels on startup.
Old Jul 14, 2016 | 08:33 PM
KING's Avatar
KING
CL Folding 25,000
Take better pictures, I'll be able to help. I've taken these headlights lots before. Just need to see what we're dealing with in the inside of the housing where the ball would usually just snap in place with a certain angle.
Old Jul 14, 2016 | 08:56 PM
Jobbyson's Avatar
Jobbyson
Ok I will pull it out tomorrow wasn't sure if you'd (someone) would know off-hand. Yeah I am beginning to believe something may be messed up. But thanks for the reply and hopefully we can figure it out.
Old Jul 15, 2016 | 12:22 PM
Jobbyson's Avatar
Jobbyson
Here is the drivers side that is intact and the passenger that is not.
#1 bad
#2 bad
#3 bad
#1 good
#2 good
#3 good
Old Jul 15, 2016 | 03:05 PM
KING's Avatar
KING
CL Folding 25,000
This black circular **** looking piece slides into the connector from the side parallel to the black mounting on the projector, and it snaps in.
If the black mounting plastic piece seems too far for it to reach, that means your projector is not aligned correctly. Try releasing the other side that is holding the projector's bowl and remove it. Then put it back again but start by snapping the **** in the mount first and THEN connect the other side.
Let us know how it goes
SoCal Cyco
Nov 16, 2014 10:55 AM
ravig292
Feb 27, 2012 07:26 PM
hemsley1
Aug 26, 2010 08:38 PM
bigcory
Dec 26, 2008 06:34 PM
