Oscillating Vent Stopped Oscillating
Old Jun 2, 2016 | 01:00 PM
LS430Lexus's Avatar
LS430Lexus
Default Oscillating Vent Stopped Oscillating
The vent on the drivers side has stopped oscillating. The passengers side works fine. Changing the settings or having someone in the passengers seat doesn't seem to make a difference. Any ideas?
Old Jun 2, 2016 | 01:38 PM
LudeAEM's Avatar
LudeAEM
Live with it, its a luxury
Old Jun 2, 2016 | 01:59 PM
bmore430's Avatar
bmore430
Try turning the on/off for the oscillating vents to reset it or disconnecting the battery?
if that doesnt work i believe there is an ecu for those vents that may have went bad.
Old Jun 2, 2016 | 02:40 PM
PolishDude's Avatar
PolishDude
happened on my dads LS430, one died 6 or 7 years ago while the other one still works perfectly to this day
Old Jun 3, 2016 | 01:02 PM
tallcaguy's Avatar
tallcaguy
ECU is one possible (and expensive) fix. The second is a failed motor. I looked at a possible '04 purchase. Test drive was great until I turned on the vents. Got a "nails shaken in a can" noise. Lex dealer said they do go bad (assume he meant motors not Lex dealers). His quote to replace both motors was $900. Good luck
Old Jun 4, 2016 | 04:41 AM
LS430Lexus's Avatar
LS430Lexus
The vent now works intermittently. My question is where are the motors located? Various vent assemblies are available on Ebay. Has anyone attempted this?
Old Jun 4, 2016 | 06:29 AM
Howzit's Avatar
Howzit
I leave mine off. Matter of fact, I leave all that automated stuff off, vents, steering wheel, mirrors. I just don't want them to break. Sometimes I ask myself the difference between using that stuff until it breaks, or just not using them at all? I don't know, I'm weird and OCD on things.
Old Jun 4, 2016 | 02:06 PM
LS430Lexus's Avatar
LS430Lexus
It's ok, you should do what makes you happy. My thinking is what are you saving for? You might as well enjoy these features while you have them. I like and use all of the features such as the tilt and telescope wheel, folding mirrors and auto-sweep. Sure, if the auto sweep stops working and cannot be repaired for a reasonable price, I will just set the vent the way I want it and forget it. At 14 years old and 153,000 miles, I am not worried about the next owner.
Old Jun 4, 2016 | 02:33 PM
MikeFoxx's Avatar
MikeFoxx
Yeah mine work all the time 90% of the time lol... don't really know what triggers them to not automatically function sometimes. When they don't work on their own I found a technique that works on my car: turn off oscillating, turn off ac, turn ac on, press oscillating... one will move till its synced with the other and them they both move.
I only have to do this maybe 2 times a week out of all the times I start it up but still don't know the real reason it happens.
Old Jun 4, 2016 | 05:12 PM
jayclapp's Avatar
jayclapp
Exactly. I use and have used all my car features since I purchased it with 21,000 miles in 2007. Use folding mirrors every time I enter and leave the garage, auto steering wheel is always on, and have never had any trouble with any those features or the oscillating vents either.
Sometime I wonder if constant usage isn't better than less frequent usage. Either way, I am not "saving" my car features for a possible future owner. I didn't buy the car to "not" use it.
Just my opinion.
Old Jun 4, 2016 | 06:12 PM
Howzit's Avatar
Howzit
I hear you. I plan on keeping this car for a long time. Maybe I'll start using those features.
Old Jun 4, 2016 | 06:27 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
^^^^^^ive been using all my features for 6 years without issues.
enjoy them!
Old Jun 5, 2016 | 12:33 PM
lorenr's Avatar
lorenr
Can't help but wonder if the vent pivots are not dirty with gunk. Get some silicone spray or even WD 40. Turn off the feature and manually spray in the lube using the supplied wand. Work it manually. Let set for a while. Do this to both vents.
See if this works.
TREYFIGGS
Oct 4, 2020 11:56 PM
Indianajef
Dec 11, 2019 08:56 AM
lserlohn
RX - 1st Gen (1999-2003)
Jun 9, 2011 06:11 AM
mkaye
Dec 22, 2009 02:33 PM
anthracitetarga
Mar 21, 2003 03:15 PM
