i just bought a 06 - couple question issues
May 6, 2016 | 02:36 PM
Quote:
Originally Posted by
mrhenry123
thx
is there a way to MANUALLY adjust the tilt wheel ? if i could get it to a spot that is comfortable i would need to fix that motor.
Yep... I did that for a while until I decided to replace the motor.
Look a the procedure documented in this link.
https://www.clublexus.com/forums/ls-...placement.html
All you have to do is
Take the plastic cover out
Unplug the motor
Remove the two big HEX screw on each side.
Adjust the steering at the position you want by screwing in or out the motor
Put everything back together except don't plug the motor... You don't want it to start moving and failing again in a awkward position
May 10, 2016 | 07:36 PM
thx going to attempt this weekend.
i am really good at taking stuff apart.... getting it back together..not so much.
MrBsfirst
Mar 11, 2016 02:24 PM
Bryan858
Jun 28, 2015 11:05 PM
appsdba
RX - 1st Gen (1999-2003)
Dec 11, 2014 07:47 PM
barronj
Jan 18, 2014 12:04 AM
dingo
Nov 26, 2002 02:04 AM
