wet carpet problem
Old Jan 31, 2016 | 05:52 PM
paulrichmo's Avatar
paulrichmo
Default wet carpet problem
01LS430 Passenger side carpets soaked with water! Anyone know whwere the drain for AC condensate is located!
Old Feb 1, 2016 | 01:34 PM
tradosauru's Avatar
tradosauru
I don't know if this would be the same but my son's 2008 ford mustang has a drain that is located under the front window cowling. Leaves would clog up the rubber grommet and rain water would back up in the car.
Old Feb 1, 2016 | 01:59 PM
Tom57's Avatar
Tom57
Was your windshield recently replaced? How does the rubber seal around the retractable moon roof look?
Old Feb 1, 2016 | 02:13 PM
lexman52's Avatar
lexman52
I would not think so but a leak in the heater core would do it. Does it have a order or color
Old Feb 1, 2016 | 02:34 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
+1 on the cowl drains.the sun roof has drains also but i dont know where they are routed.
Old Feb 1, 2016 | 06:36 PM
paulrichmo's Avatar
paulrichmo
tHANKS TO ALL FOR REPLIES! tHE WINDSHIELD WAS NOT REPLACED, BUT IT WAS FIRST CLUE THAT SOMETHING WAS AMISS it was all fogged up on couple mornings,bu tcleared with defrost. I didnot notice the wet rugs till my wife said Im not getting in there in all that water> It is not anti freezz . SO I TOOK HER IN MY WORK VAN....Parked it removed seats and used two weed blowers to dry under the foam and vcarpet. Will not use ac till problem solved. Thanks to all again
Old Feb 4, 2016 | 05:46 PM
paulrichmo's Avatar
paulrichmo
AC drains on underside put finger in and feelbetween doorpost and exhausrc pipe 2inch dia. hole 6 inchs from exhaust. Put finger in hole to feel rubber hose. There is another on opposit side of car. I used compressed air to blow the clog up. Probably have to dreal with it again,unless I can clean it another way.
Metlupass2
Jun 11, 2021 10:15 PM
draco
Sep 30, 2019 12:55 PM
HOLGER21
Dec 21, 2012 10:02 AM
nvman21
RX - 1st Gen (1999-2003)
Jul 11, 2011 09:18 AM
hieu
Aug 17, 2009 08:01 AM
