corning lights
Old Aug 17, 2015 | 05:18 AM
johnnylt's Avatar
johnnylt
Default corning lights
I have a 2005 LS 430 with the Levinson package (step down from ultra) and it amazes me , this expensive automobile does not have corning lamps? When you activate the turn signals? Ive had Avalons , Infinitis they all had them .Surprises me Lexus could not spend a few extra bucks for a wiring harness and a bulb and they would fit perfectly into the fog light assembly on the corners?
Old Aug 17, 2015 | 05:25 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
The Adaptive Front-lighting System (AFS) helps illuminate a turn or curve as the driver steers into it. I thought that was standard on LS - does your car not have it (swiveling the headlights)?
Old Aug 17, 2015 | 06:32 AM
Anthony81's Avatar
Anthony81
The AFS is only active above speeds of 6 miles per hour. I do like cornering lights on cars to help see pedestrians when stopped at an intersection.
Old Aug 17, 2015 | 10:46 AM
KING's Avatar
KING
CL Folding 25,000
Yep, it's standard. You'll see it activate above a certain speed, and shut off at a certain speed.
Old Aug 17, 2015 | 04:45 PM
doyo's Avatar
doyo
They're on the Japanese vehicles (and possibly everywhere else RHD). They got removed from the US/Canadian vehicles, at the very least. Not sure why. Reflectors are still in the assembly, but no hole for the bulbs.
I believe some people have simply drilled/cut their own to fit a bulb, but not sure how wiring would go to make it function as a cornering lamp. I've been itching to wire in a pair of bulbs that turn on alongside the foglights for more side coverage, but it'd probably be out of DOT regulation or whatever, and cause some glare as there is no shielding.
Old Aug 17, 2015 | 05:28 PM
Tom57's Avatar
Tom57
There's a JDM lamp assembly that has socket openings for both a fog light and a turn signal light.
toddharshm
RX - 4th Gen (2016-2022)
21
Apr 8, 2019 01:19 PM
wolfy187
Jul 29, 2012 05:20 AM
iamviolet
Mar 20, 2010 02:21 PM
ryanSC400
Nov 26, 2006 05:13 PM
MadMax96
Jan 26, 2006 08:52 AM
