Loud Noise from Passenger Front
Old Jan 8, 2015 | 08:43 PM
rajmangal7's Avatar
rajmangal7
Default Loud Noise from Passenger Front
Hey guys, I have a 2004 Lexus LS430 and it has about 118,000 miles. When i am at about 40 and above there is the loud noise coming from the front wheel like something is rubbing, faster i go louder it gets. It doesn't affect drivability of the car, but i don't know what it is. I just replaced my rotors thinking it was them along with my breaks. It brought the noise level down very little. I don't know what to do. Any advice? Bearing?
Old Jan 8, 2015 | 08:47 PM
Lavrishevo's Avatar
Lavrishevo
My first guess would be wheel bearings.
Old Jan 9, 2015 | 12:18 AM
rajmangal7's Avatar
rajmangal7
Are they able to be bought at the local part store? difficult to replace?
Old Jan 9, 2015 | 06:43 AM
Tom57's Avatar
Tom57
At that mileage, most likely the wheel bearing(s). To isolate which one, test the right front bearing by making left turn and listen for sound; test left front bearing by turning right and listen for sound. Too bad you'll have to re-do work you did to replace rotors. The hardest part of the job is punching (hammering) out the old bearings that can get crusty in place. Use a heavy hammer with punch tool and wear gloves.
Old Jan 9, 2015 | 08:21 AM
KING's Avatar
KING
CL Folding 25,000
If you've been having the problem for a ling time then definitely check your rotors as well.
Machine them if they still have life in them, or new ones off of Sewell.
That's a classic wheel bearing issue. Replaced mine a month ago after hitting a curb when it snowed.
I definitely have defects in my rotors and I should have something done about it this weekend.
Old Jan 9, 2015 | 08:25 AM
Tom57's Avatar
Tom57
The OP just replaced rotors and brake pads ...
Old Jan 9, 2015 | 09:01 AM
BradTank's Avatar
BradTank
Also, check the backing plate that's behind your rotors.
It's a piece of sheet metal that can easily be bent and make contact with the rotors, I know I've made that mistake after working on the brakes and it will have a noise like you're describing. I just bend them back away from the rotor.
The fact that you just did the rotors and you now have this noise tells me it could likely be that.
Old Jan 9, 2015 | 03:23 PM
rajmangal7's Avatar
rajmangal7
Thanks for the help guys. I hope the local parts store has the wheel bearings.
Old Jan 9, 2015 | 05:46 PM
Tom57's Avatar
Tom57
Suggest you don't buy the cheapest bearings ...
Old Jan 9, 2015 | 06:51 PM
arcteryx's Avatar
arcteryx
This. Timken is a good brand, Autozone carries them.
Old Jan 9, 2015 | 10:32 PM
rajmangal7's Avatar
rajmangal7
Appreciate it guys, i'll check it out tomorrow morning. When i turned left it got louder.
Old Jan 9, 2015 | 10:43 PM
rajmangal7's Avatar
rajmangal7
simpson227
Aug 10, 2018 12:44 PM
Bocatrip
Mar 2, 2016 09:56 PM
Behemoth7
Dec 2, 2014 10:34 PM
Nosexnolex
Jul 25, 2012 02:57 PM
Jrezo
Jan 5, 2011 11:08 PM
