So I have been changing oil with castrol syntec with original toyota oil filter. I have changed the schedule for 10k on my nav system but just noticed the red maintenance light turned on at about 5500 miles. Any method to change the setting other than the nav system so it doesn't trigger the light until 10k? Thanks and happy holidays.
The distance setting on the Nav system for oil change does not control the "Maintenance" light on the dash. They are separate and independent. The on-dash oil Maintenance light is set at factory. Check your Owner's Manual.
I think the OP wants to have the on-dash Maintenance light set to a 10,000 mile interval for oil changes (which can't be done). He'll have to set the Nav screen oil change reminder to 10,000 and rely only on it, then simply reset the on-dash maintenance light (per the instructions) every time it turns "on".
