Replacing the Engine Temperature Sensor
Old Apr 20, 2019 | 05:19 PM
  #46
Peacebay's Avatar
Peacebay
Thing is, the coolant temp sensor will never really fail, in a tangible sense. So a lifetime warranty is really useless.
A well functioning, quality sensor will send the most accurate data to your ECM, keeping your fuel trims optimal.
I spent $35 bucks on my OEM Lexus sensor. Cheap insurance.
Old Apr 20, 2019 | 05:24 PM
  #47
westopill's Avatar
westopill
Where did you find it for $35?? I looked around and even Mylparts sells it for at least $60. If I could get it for that price I'll just return the one I got..
Old Apr 20, 2019 | 05:36 PM
  #48
Peacebay's Avatar
Peacebay
eBay is your friend
Old Apr 20, 2019 | 07:03 PM
  #49
westopill's Avatar
westopill
Hah, I wouldn't have thought eBay for my OEM parts. Seems a little sketchy but the seller seems reputable. I'll hop on this when I get the chance, and in the mean time I'll run with the Oreilly brand and see if my MPG improves.
Old Apr 20, 2019 | 10:55 PM
  #50
ls430w140's Avatar
ls430w140
Amayama has good deals for oem coolant sensor last starting from 31 dollars plus small delivery fee, in case if you don’t trust eBay (which I understand as I am in the same position sometimes).
Old Apr 28, 2019 | 12:32 PM
  #51
Nphoops's Avatar
Nphoops
I changed out the sensor yesterday. Engine cold, no coolant spilled out. Bought a sensor at Advance Auto (25% off). The replacement came with thread tape! Very easy replacement, took 15 minutes.
Old Aug 9, 2019 | 12:16 AM
  #52
bd3471's Avatar
bd3471
Any update on MPG? I get 21 MPG max on HWY but envious of those who report 27.
Old Aug 10, 2019 | 06:39 AM
  #53
Bigno366's Avatar
Bigno366
Default Sensor
Hey can anyone help my LS430 it seems to try to run hot when the AC is on but soon as I turn it off after a few minutes temperature drop to normal what could it be
Old May 1, 2021 | 08:05 AM
  #54
Notyoujohn's Avatar
Notyoujohn
Default Qstn
My lexus 3uz engine its not recording temperature bt i have seen some cables cut on the cluster connector so im thinking that where there problem is. So i got 2 questions here
1. What is the cable colour for temperature gauge ?
2 . From the temperature sensor does it goes through the engine control box (computerbox)?
please help
Old Feb 14, 2022 | 08:56 AM
  #55
ThomasD94's Avatar
ThomasD94
Originally Posted by Lavrishevo
I put in my new engine temperature sensor today. It was actually very easy. Just remove the air tube between the air filter and the throttle body and you have easy access. A 19mm deep well socket will easily remove it. Also gave the throttle body a little cleaning and the little idle port on top as well. I did not know about the port until DockOf-Bay mentioned it. Between cleaning the idle port and replacing the sensor she is really running great. A lot accomplished today.
A few pics of the process and the old sensor. In my opinion, antifreeze really does a number on the sensor and it should be replaced at the 90K service.
Thank you so much for this!
JH48
May 14, 2019 11:44 PM
Beny
RX - 1st Gen (1999-2003)
Jan 23, 2018 12:21 AM
grumpy55
14
Feb 1, 2017 05:05 PM
slash
Mar 5, 2005 05:48 AM
sc300jon
May 21, 2001 06:27 AM
