Center Console Arm Rest Refresh DIY
Old Oct 6, 2013 | 10:48 AM
BT3100's Avatar
BT3100
Lightbulb Center Console Arm Rest Refresh DIY
I have been looking to replace my center console arm rest for a while. Price at the dealer was way too much so I have been looking on ebay etc. I just recently noticed that someone on ebay was selling new leather covers for the arm rest. He was selling an ivory/tan leather that looked like a perfect match for my Ecru interior. For $50 I gave it a shot. When the replacement skin arrived I was surprised at how close it matched my interior.
First Pic is the before.
Second and third pics are the "new skin"
Fourth pic are the screws I removed under the console to remove the arm rest.
There are 12 screws to remove. 8 small and 4 larger screws at the bottom of the arm rest. Once these are removed the cover will come off with a little wiggling to free up the air vents.
Once removed I pulled out the staples holding the old skin on the arm rest.
The new skin was templated perfectly. There were marks on the back for where to cut. I only needed to cut out the hole for the rear air vents. I tried to use my pneumatic stapler to attach the new skin but it was too strong. Tried an arrow stapler but it was too weak. I ended up using a hot glue gun and some large paper clips to hold while the glue dried.
The work took 30 minutes, add 60 minutes for the glue to dry and to remount and it's a 90 minute project. Looks great and the color really matches. I am planning to "refinish" the seats next week.
Attached Thumbnails Center Console Arm Rest Refresh DIY-1.jpg   Center Console Arm Rest Refresh DIY-2.jpg   Center Console Arm Rest Refresh DIY-3.jpg   Center Console Arm Rest Refresh DIY-4.jpg   Center Console Arm Rest Refresh DIY-9.jpg
Old Oct 6, 2013 | 01:18 PM
SBlexus's Avatar
SBlexus
Nice job, the color looks great.
Old Oct 7, 2013 | 10:28 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
Excellent work! I need to try this on my SC300.
Old Oct 7, 2013 | 01:12 PM
walleyeman's Avatar
walleyeman
Nice write up and job. Looks good.
Old Oct 7, 2013 | 04:13 PM
AlexusAnja's Avatar
AlexusAnja
How is the piping along the edge? Seems thinner and stitched. Color is a good match but looks baggy around the edges.
Old Oct 7, 2013 | 04:16 PM
BT3100's Avatar
BT3100
The piping is good and consistent. I intentionally left it a big baggy as I did not want the piping to be crooked. I think if I were to do it again it would look neater. A few people were in the car today and I asked them if it looked ok. They both though it was a factory replacement.
Old Oct 7, 2013 | 08:19 PM
HVLSTON's Avatar
HVLSTON
Nice write up. Make sure to do a write up on your seats as well when you get them "refinished".
Old Oct 7, 2013 | 09:32 PM
C8V6C's Avatar
C8V6C
Nice man, I'll keep this in mind later down the road, since we have the same color interior
Mines a little worn, but not bad enough for me to change it just yet :P
Old Oct 9, 2013 | 12:45 PM
fensterlip's Avatar
fensterlip
Default Alternatives When It Just Needs Refinishing
That looks really nice and I think it was a good choice.
Just as an alternative for those that want to try refinishing the factory cover first - I've found a pretty good alternative. Try the leather shop and refinisher at leatherique dot com. George sells a really high quality leather refinisher including color matching and a leather filler that can make almost anything look new.
In addition, he has a line of leather cleaners and softeners that can keep your leather soft and supple. I've used it for years in many cars and in a couple cases redid entire interiors to like-new condition.
Old Dec 16, 2021 | 02:25 PM
LEX311's Avatar
LEX311
9th Gear
Looking to resurrect this thread, I removed all 12 screw and I can’t for the life of me pry open the leather wrapped lid from the plastic substrate . I’ve read on this forum that I might need to remove the air vents in the rear of the center console and that will reveal some more screws. Can anyone confirm this before I damage anything . Thanks in advance!
matt
Old Dec 17, 2021 | 08:54 PM
caverman's Avatar
caverman
I want to do the same sometime soon only I want to also add some more padding which is my main center console issue.
Old Dec 18, 2021 | 04:12 PM
Paulanth's Avatar
Paulanth
Default Arm Rest Refresh
BT3100 - Can you provide the new cover
supplier’s web address, etc. for our
Forum members?, because it seems
you got it from a very good source.
Thanks
Old Dec 20, 2021 | 04:33 AM
BT3100's Avatar
BT3100
Thanks
Hi.
looked on ebay and couldn't find the exact seller but found a seller that i bought an arm rest off of for my 460.
I attached a photo
Old Jan 1, 2022 | 09:44 AM
caverman's Avatar
caverman
matt
Did you get yours figured out? I did mine yesterday and took quite a few pictures along the way. It was a little tricky to figure it out but I finally got it off. Once you get all the screws off then it should just come right off. You're probably missing some screws you need to remove. I'll start a new thread in a little while to show what I went through.
Old Jan 5, 2022 | 07:12 PM
CA2WALS430's Avatar
CA2WALS430
If you are into OEM, Mylparts is showing $145, but it is strange because it says "this part does not fit your 2004 LS430", but obviously I had it typed in, so you would have to call or email them and get the scoop.
Lveyolfe
Dec 22, 2021 02:32 AM
oztiks
Oct 19, 2016 07:53 PM
RebulRigo
Feb 13, 2013 08:02 AM
tyncobb
Maintenance
Dec 15, 2004 02:48 PM
