amp compatibility
Old May 5, 2013 | 01:01 PM
GSXOTIC's Avatar
GSXOTIC
Default amp compatibility
Any help is appreciated. Does anyone know if the pioneer amp is 100% compatible and 100% plug and play on a ml system in 2006 LS430?
Old Dec 22, 2017 | 06:39 PM
GSquicksilver's Avatar
GSquicksilver
Bringing up an old thread. I'm in the same boat currently and was wondering the same. Anyone done a swap?
Old Dec 22, 2017 | 07:44 PM
05ls430518's Avatar
05ls430518
I doubt it would work the marks levinson amp controls the nav unit and climate control while the pioneer does not they are completely different.
Old Dec 23, 2017 | 05:30 AM
Jabberwock's Avatar
Jabberwock
A ML for pioneer amp swap is a bad idea primarily because the ML amp runs different speakers with significantly different ohm ratings. I have a premium option LS and my pioneer amp stills sounds pretty good for 12 years old. If I did replace the audio HW I'd go with non OEM and get a head unit and amp designed in the current century.
Old Mar 5, 2021 | 10:00 AM
daffy1029's Avatar
daffy1029
10th Gear
Default intermittent amp
Before going too far with replacing this and that, go into the trunk on the passenger side, and take out the trunk covers. There you will see the ML amp. Take out the connectors and clean up the contacts. Use some dielectric grease on the contacts and replace the connectors back on the amp. Hopefully this will solve problems for you, and if so, that is the cheapest fix. I found some videos on youtube indicating how to do this.
stopdrpnro
Jan 21, 2026 08:24 PM
eld664
Nov 9, 2008 09:32 PM
dacecil
Nov 9, 2008 07:18 PM
