Center consule will not open 2003
Old Sep 18, 2012 | 05:48 PM
wmbinford's Avatar
wmbinford
Default Center consule will not open 2003
I read sigers98 post on 2/9/08. But I wonder if it is necessary to take the center console out to get it open? The opening handle just seems not to release the latch. I was hoping I could trick it open and find a way to see if the linkage to the latch itself could be repaired or jury rigged. Help appreciated - new Lexus LS430 owner.
Old Sep 18, 2012 | 10:59 PM
VIPDrizzy's Avatar
VIPDrizzy
Not unless you have something strong enough thin enough and flexible enough to try and slip in it.
Old Sep 19, 2012 | 04:02 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
have you tried to push on the back side of the lid toward the front of the car and lift the handle?
Old Sep 20, 2012 | 04:20 PM
Chemtj's Avatar
Chemtj
As jimbosr1 said push from the rear as you are lifting the handle. Once open look at the center console lid fix thread. The screws that hold the lid to the hinges are loose or have fallen out. Just finished fixing mine literally 10 minutes ago, for the second time. Do not use locktite! I used some small star lock washers the second time.
Old Sep 20, 2012 | 04:32 PM
john339's Avatar
john339
a little rubber cement on the screws before re-installing them will hold them from vibrations. Rubber cement will not harm the plastic.
Old Sep 22, 2012 | 01:36 AM
wmbinford's Avatar
wmbinford
Default pushing from the back did it!
Thanks though I feel rather stupid right now.
Old Oct 9, 2012 | 08:06 PM
wmbinford's Avatar
wmbinford
I removed the console, which was easy, and sure enough the two screws were missing. I replaced them which was a little difficult because my screw driver was not magnetized and I can be a klutz. I replaced the console, which was easy and the thing works as advertized. Less than 45 minutes including a beer (which may have had something to do with the putting in new screws!) Thank you!!
HealP
RX - 3rd Gen (2010-2015)
Feb 26, 2018 06:12 AM
ddoo3105
GX - 1st Gen (2003-2009)
Jan 17, 2017 07:35 PM
jds4u2
Sep 2, 2016 12:21 PM
S1w99
Sep 2, 2015 10:20 AM
iewiew
Jun 18, 2009 02:16 PM
