How do I change a console, shift indicator on a 2002 ls430
Old May 5, 2012 | 03:27 PM
DjMidas's Avatar
DjMidas
Default How do I change a console, shift indicator on a 2002 ls430
I'm having a hell of a time getting this part out. If you don't know what it is..... Its the piece of gray plastic around the shifter stick. It has the gear labels on it. I got the chrome bezel off but Im stuck at that point..... don't want to break anything. Any one have a step by step picture diagram?
Old May 5, 2012 | 03:53 PM
SQuester's Avatar
SQuester
Its part of the shifter assembly, and the gear indicator panel might not be removable without having the whole assembly out of the car, which likely requires disassembling the center console first.
Old May 6, 2012 | 05:10 AM
Kansas's Avatar
Kansas
The 02 LS shift lever assembly looks just like the one in our Camry in which I replaced the gear indicator bulb. On the Camry, I popped the position indicator off and slid it up the shift lever shaft. I don't remember if it was held in place by screws on the side or friction tabs. I don't see any screws in the attached diagram so maybe the position indicator can be pried off.
Attached Thumbnails How do I change a console, shift indicator on a 2002 ls430-2002-ls430-shift-lever-diagram.jpg
Old May 7, 2012 | 06:30 AM
Lynzoid's Avatar
Lynzoid
I replaced mine (gray piece) without ANY problems. 4 snap-tabs and it's off. Be careful.
Old Oct 1, 2012 | 09:46 AM
jls667's Avatar
jls667
How did you replace the shifter bulb? Did you need to remove the center console? I have an 2004 LS430.
Old Nov 7, 2012 | 11:23 PM
cyguy's Avatar
cyguy
i'm trying to do the same with my 2002 is300 - light indicators out in center piece
Old Nov 8, 2012 | 04:14 AM
Lynzoid's Avatar
Lynzoid
You need to take out whole trim panel. It's easy tho.
Old Jul 19, 2025 | 05:01 PM
AussieLS430's Avatar
AussieLS430
2nd gear
I made a video:
Hope it helps
bfg23
Feb 28, 2015 04:56 PM
liners1
Nov 3, 2013 04:23 PM
chex
Nov 18, 2010 06:22 PM
kg19989
Mar 30, 2010 10:51 AM
mcnelson
GS - 1st Gen (1993-1997)
Feb 28, 2003 08:20 AM
