Need help finding a part #
Im looking for the part number of the tail lamp failure indicator/sensor on the 04-06 LS430. If anyone knows the part number please let me know.
TIA
TIA
I searched the sewell site and could not find the part. I know that they dont list everything there. If you have the part # and punch it into the search box then it will show up. Thats why Im looking for the part #
I need the part number for the sensor (or whatever it is) that lets you know when a tail light bulb is out. Reason I put sensor/indicator is I seen it called different things when I was searching for it online.
Make sure the replacement bulb is identical to the stock bulb. Check the base for brass v. tin. Some lamp monitors can get fooled if you change bulbs and put in a bulb with a different base.
BTW, a bulb monitor can be triggered by a bulb that is starting to go bad but hasn't blown yet.
Well according to junjdm when he did the face lift from 01-03 to 04-06 he replaced this part to get rid of the tail lamp failure warning on the dash. I asked him for the part # but he said he didnt remember and didnt seem to want to help me out. I changed my tail lights to LED so I get the warning. I aslo am thinking of doing the face lift and this is a part I cant seem to find a part # for.
https://www.clublexus.com/forums/4862119-post76.html
https://www.clublexus.com/forums/6359868-post93.html
https://www.clublexus.com/forums/6434861-post95.html
5gears-IS
Mar 14, 2016 10:06 AM
