"tail lamp failure"
Old Apr 9, 2011 | 08:35 AM
jjlxs's Avatar
jjlxs
Default "tail lamp failure"
Hello,
are there any angels to solve my "tail lamp failure" problem?
2001 ls 430.
I changed all lamps, and still warnning signal "tail lamp failure"
when i turn on head light.
What could be the reason and how i can handle this.
Please, anybody help me!!
Jjlxs
Old Apr 9, 2011 | 09:51 AM
stock_sc's Avatar
stock_sc
have you checked your high brake bulb? that can be the issue with the earlier models.
Old Apr 9, 2011 | 09:52 AM
caddyowner's Avatar
caddyowner
Welcome! Did you check your CHMSL (center high mount stop light)? Also, some brands are sensitive as to the type of replacement bulbs used (tin base v. brass base) and will continue to indicate a failed bulb if the base types are mixed.
Old Apr 11, 2011 | 08:41 AM
jjlxs's Avatar
jjlxs
Default thanks
thank you for your advice!
i will try again to change high center brake light bulb.
again, thank you !!
jjlxs
Old Apr 11, 2011 | 08:44 AM
jjlxs's Avatar
jjlxs
Default many thanks!!
caddyowner,
i really thank you !!
i will tell machanic to check if any bulbs are mixed in base(tin/brass).
your advice looks really could be answer.
thank you again!!!
jjlxs
Old Dec 15, 2011 | 01:12 PM
lex2lex's Avatar
lex2lex
Default Tail lamp warning went off
Hey guys, I had a brake wear warning fixed by changing the wear sensors and that seemed to turn off my "tail lamp failure" warning.
BTW napa auto parts had the best price for the brake wear sensors ($11 bucks) that sure beats the $90 + I've seen other places.
Old Dec 15, 2011 | 02:35 PM
lex430drvr's Avatar
lex430drvr
When you changed all the lamps, were they to original spec or were they upgraded or changed to LED bulbs or any other types? Also, after changing it, did you check to make sure all the lights were working or were any of them not functioning?
Old Sep 8, 2013 | 06:34 PM
Saman704's Avatar
Saman704
Default Wrong Bulb
Advance Auto listed the 194 bulb as a replacement for the high mount taillight. The bulb failure warning light would not go out. Checked at Auto Zone and they list the 168 bulb. Replaced all 5bulbs with 168 bulbs and the lamp out warning went off. Apparently while the 194 bulbs will fit and work, the wattage is different.
Old Sep 9, 2013 | 03:25 PM
69charger's Avatar
69charger
Default tail lamp light
Originally Posted by jjlxs
Hello,
2001 ls 430.
Jjlxs
My tail lamp out light was the license plate light and also the front parking lamp light. Good luck
caverman
Sep 21, 2017 03:21 PM
mate01
Jun 9, 2016 03:01 PM
PL372
RX - 3rd Gen (2010-2015)
May 4, 2015 11:39 AM
jay33
Aug 20, 2012 05:41 AM
hoonami
May 3, 2007 03:25 PM
