Rear camber adjustment
Old Apr 25, 2011 | 07:20 AM
  #91
User 82021's Avatar
User 82021
Originally Posted by 06~ULTRA
just like camber arms on radio controlled cars. with the turn knuckle on the center of the threads. from their once you get the camber set by a shop, you can make adjustments if needed yourself by keeping track of how many rotation. simple yet affective.
anytime you adjust camber on these cars you will have to adjust toe. so that being said, anytime you make an adjustment you have to have an alignment done.
Old Apr 25, 2011 | 07:57 AM
  #92
Mr.Doback's Avatar
Mr.Doback
lowered430 - did you make the arms? I really like the design on those.
Old Apr 25, 2011 | 10:54 AM
  #93
06~ULTRA's Avatar
06~ULTRA
so, if you what to increase/decrease camber by let’s say 2 or 3 degrees. would it be necessary to do an alignment after this? Im just wondering if a couple degrees make much of a difference.
Old Apr 25, 2011 | 12:25 PM
  #94
Celsior21's Avatar
Celsior21
^ yes any camber adjustment will throw off the toe. So alignment is pretty critical.
Old Apr 25, 2011 | 12:45 PM
  #95
FIGS's Avatar
FIGS
The Maker
Got both arms welded over the weekend. Will post as soon as I can whe I fully assemble.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Apr 25, 2011 | 12:57 PM
  #96
FIGS's Avatar
FIGS
The Maker
I will have two versions, one will not require the full rotation of the sway and headlight. The other will be static set. I have built of the turbuckle version first.
__________________
Old Apr 25, 2011 | 01:48 PM
  #97
notserp's Avatar
notserp
^^^can't wait to see it
Old Apr 25, 2011 | 03:06 PM
  #98
HiloDB1's Avatar
HiloDB1
Mike
Cant wait!!!
Old Apr 25, 2011 | 05:14 PM
  #99
monkeybutt's Avatar
monkeybutt
When I asked lowered430 about these on another thread he said Azcamber made these. From the pics above it looks like neat work.
Old Apr 25, 2011 | 10:52 PM
  #100
FIGS's Avatar
FIGS
The Maker
Sneak Peakaboo. Still a few things that need verification... like the sway endlink clearance and I still need to machine down the inward spacers to the correct gap. All in all pretty happy so far though.
__________________
Old Apr 25, 2011 | 10:55 PM
  #101
HiloDB1's Avatar
HiloDB1
Awww skeet skeet. Awesome job on the arms
Old Apr 26, 2011 | 11:52 AM
  #102
VNN326's Avatar
VNN326
OH MY GODDD!!
Old Apr 26, 2011 | 02:35 PM
  #103
Mr.Doback's Avatar
Mr.Doback
So hyped!
Old Apr 26, 2011 | 03:21 PM
  #104
sojah's Avatar
sojah
scarry pic thing, but funny nonetheless
Old Apr 26, 2011 | 08:38 PM
  #105
Celsior21's Avatar
Celsior21
This is looking promising!
