Rear camber adjustment
Old Jun 16, 2011 | 01:13 PM
  #151
Selah777's Avatar
Selah777
yep looks about right
Originally Posted by Mr.Doback
bump for camber!
Old Jun 19, 2011 | 09:23 AM
  #152
Mr.Doback's Avatar
Mr.Doback
just got an alignment....
-3* up front
-4* in the rear
all toe in spec.
Based on cam bolt for tierods, i should be able to pull up to -6 without adjustable tierods.
Old Jul 1, 2011 | 12:53 PM
  #153
gatornaz's Avatar
gatornaz
Hello. Just bought an 03 LS430 UL and it has the Camber issue on the left rear where it is riding on the inside of the tire and wearing it out. Does anyone here know of a shop in or around Phoenix other than a dealership that knows how to fix this properly? I found the different length control arms on the Carson Toyota website for $139.09 each, but also read the Toe has to be adjusted as well. This is a great group with lots of insightful information I used prior to buying the 430. Thanks everyone for all the great information on the LS430
Old Jul 1, 2011 | 03:32 PM
  #154
Mr.Doback's Avatar
Mr.Doback
From what it sounds, your car is not lowered at all.
In that case, it sounds as if something is bent. The rear arms on Ls' do not have adjustment except for Toe which is done with the cam bolt.
Any competent alignment tech can adjust the problems, but until its on a rack, its hard to say what your problem is as you may only have an issue with toe.
Old Jul 3, 2011 | 08:02 PM
  #155
FIGS's Avatar
FIGS
The Maker
proto arms shipped out for testing. Will get some feedback and might try to release within the month.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Jul 3, 2011 | 09:35 PM
  #156
Dutchie101's Avatar
Dutchie101
Hows work going on the rear toe arms?
Old Jul 3, 2011 | 10:19 PM
  #157
dejavu157's Avatar
dejavu157
I want more camber on my ride, but my allignment guy told me there isnt one to adjust on the car. How do i get more, while staying in spec for with the toe. I want to drive around like Selah777
Old Jul 12, 2011 | 01:10 AM
  #158
bobo001's Avatar
bobo001
any updates or feedback on prototypes?
Old Jul 12, 2011 | 04:41 PM
  #159
FIGS's Avatar
FIGS
The Maker
Installed and everything went well. Waiting for more pics from my tester
__________________
Old Jul 13, 2011 | 09:48 PM
  #160
mrxeb38's Avatar
mrxeb38
Man those arms are gonna be awesome!
Old Jul 21, 2011 | 05:36 PM
  #161
HiloDB1's Avatar
HiloDB1
Old Jul 21, 2011 | 07:09 PM
  #162
weizs13's Avatar
weizs13
are they avialiabe on your site ?
Old Jul 21, 2011 | 07:48 PM
  #163
HiloDB1's Avatar
HiloDB1
-3* up front
-4* in the rear
all toe in spec.
How did you get so much camber on the front? My alignment guy could only go -1.9* on the front and still keep the toe in spec. My rears are at -4.1*
[IMG][/IMG]
Old Jul 22, 2011 | 06:43 AM
  #164
sojah's Avatar
sojah
Those arms look so so nice, I forget but has a price been mentioned yet?
Old Jul 22, 2011 | 06:45 AM
  #165
sojah's Avatar
sojah
When I just changed from a stretched tire to a non stretched tire it definitely reduced the negative camber so I would also say the same holds true going the other way as well. If u run ona a super stretched tire it will force the car to have a little more negative camber, this can't be too good for anythin though.
