Is this offset Possible?
Old Sep 6, 2010 | 04:26 AM
CelsiorAUS's Avatar
CelsiorAUS
Default Is this offset Possible?
Guys I have bad news.
I bought a set of Leon Hardiritt 19 inch 9 and 10 inch rims. I just found out the fronts dont clear the BBK. so I need spacers.
I have ordered 25mm offset but the rims at +24mm anyway This means my front rims will be -1mm offset
This is just crazy isnt it? Will this even fit?
Old Sep 6, 2010 | 06:38 AM
waijai's Avatar
waijai
Are you sure you need 25mm to clear? I'd say a 15mm spacer would be perfect as far as good fitment. If anything, you can do a slight pull to the front fenders.
Old Sep 6, 2010 | 12:26 PM
CelsiorAUS's Avatar
CelsiorAUS
I dont know how long i need actually. I had it on and it wouldnt sit on the hub properly but its hard to discern whether i needed 15 or 25 mm.
Is there any mathematic calculation I can use?
Old Sep 6, 2010 | 01:47 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
A 15mm spacer should do the trick. Just use a ruler and measure out from where the wheel would sit on the mounting pad to the brake caliper. If that distance is 14mm or less, then a 15mm spacer will work. I recommend going with H&R spacers since they are hubcentric, and if you don't mind changing out the wheels studs. If you don't want to change out the wheels studs, then go with Project KICS spacers. I suggest getting the Project KICS hubcentric adapters as well since the spacers aren't hubcentric like the H&Rs.
Old Sep 6, 2010 | 01:54 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
thats gonna need a nice front fender working.
Old Sep 6, 2010 | 09:20 PM
CelsiorAUS's Avatar
CelsiorAUS
Licelsior. Is this an opinion or knowledge? I need some defintive answers to go forward as i dont want to do anymore than roll my fenders
Old Sep 6, 2010 | 09:36 PM
Vincent123's Avatar
Vincent123
uh 19x9 -1 will need fender pull for sure. A slight fender roll aint gonna cut it
Old Sep 6, 2010 | 09:51 PM
CelsiorAUS's Avatar
CelsiorAUS
how about 19 x 9 +9 if i go to 15mm spacers i mean is this all guess work or has it been done before
Old Sep 6, 2010 | 10:03 PM
Vincent123's Avatar
Vincent123
Well if you dont wanna pull, I guess you can go with like a 215 or 225 tire and roll it flat. If it rubs then camber in a bit more.
http://www.rimtuck.com/setup.php?id=465
20x9.5 +1 up front but fenders are pulled
Old Sep 6, 2010 | 10:22 PM
CelsiorAUS's Avatar
CelsiorAUS
Ah that looks good. Well i can pull my fenders a bit depending how much itll cost to respray them. Also if i go back to stock I dont want it to look funny.
How exactly do you roll a tyre flat. Currently I have 235 up front
Old Sep 7, 2010 | 02:21 AM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
By rolling, he's talking about rolling the front fenders flat, not the tire.
Old Sep 7, 2010 | 02:51 AM
CelsiorAUS's Avatar
CelsiorAUS
ohh lol oops haha..
Ok so i cut out a cd case and used it as a fake hub and a 15mm spacer should be good. Thanks for the advise above not to get the 25mm.
Now going from the link of the LS430 With low offsets i will roll fenders and stick in an inch or 2 of camber and it should be all good.
ct200
IS F (2008-2014)
Jun 23, 2014 04:01 PM
jumpboy023
15
Jan 5, 2008 07:08 PM
SPEED&ECO.
May 13, 2007 12:01 PM
JDMUSCLE
Wheels, Tires & Brakes Forum
Jan 9, 2006 08:58 PM
