I have a question will i need anything else if i put on 12.5mm spacers? I have heard that longer wheel studs may be needed but im not too sure. Enlighten me someone please!
why not just get the Project Kics 10mm hub/wheel centric Spacer with built-in studs? You just bolt the spacer on your existing studs and your wheels on the spacer studs.
thats not a bad idea.. any i dea where i can get a hold of a set?
It would be best to get a set of custom spacers made that are wheel/hub-centric. This way you know your wheels are stable. Do a search on wheel spacers and you will find what you need.
