Engine Idle Low
Old Apr 22, 2010 | 12:36 PM
toantran99's Avatar
toantran99
Default Engine Idle Low
My 04 LS Modern Lux has about 115k on it now. Replaced 8 spark plugs about 10k miles ago since my engine idle low at around 400rpm.
My engine idle is still low after the new spark plugs, any ideas on why it's low or is there a way to increase it?
Old Apr 23, 2010 | 06:15 AM
GeorgeT's Avatar
GeorgeT
Is it causing a problem? If not, I would leave it alone. Also, are you sure your tach is correct?
Old Apr 23, 2010 | 08:09 AM
toantran99's Avatar
toantran99
Only concern is if the rpm is around 300-400, engine is shaking the steering wheel a little. But the car drives fine.
Old Apr 23, 2010 | 04:26 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Just to see if this is the famous low engine idle issue, does the problem fade away when you turn on the headlights and foglights? (or AC)
Old Apr 24, 2010 | 12:48 PM
toantran99's Avatar
toantran99
Going to give it a try. Never thought about it.
Old May 1, 2010 | 11:21 AM
toantran99's Avatar
toantran99
Nope, fog light or ac is not the issue. This is happening randomly. Maybe it's the cheap gas but I always use 93 premium from Shell.
Old May 2, 2010 | 11:42 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
I know they are not the issue, but does idle come back to normal when any of those two are operational?
Old May 3, 2010 | 05:19 AM
Jabberwock's Avatar
Jabberwock
Did the low idle really start at spark plug change? If so then it may be something was messed up during the process of installing the plugs. Go back and inspect all rubber fittings, vacuum hoses and electrical connections anywhere in the engine bay and particularly around areas that might have been touched/bumped during the spark plug work. Look for disconnected items or just loose or partial or torn connections in any of the air/vacuum hoses and or electrical connections. its worth a shot to double check if the low idle actually started right after the plugs were replaced. I assume the plugs are right type and were installed properly.
Old May 3, 2010 | 09:49 AM
toantran99's Avatar
toantran99
The happens before the plugs was changed also. I think it's the cheap gas.
"I know they are not the issue, but does idle come back to normal when any of those two are operational?"
Nope, seems like it would stay around 400rpm. I think it's the gas.
GRAND_LS_4, where are you located in NOVA? I've lived up there for 20 years.
Currently reside in Richmond VA
Old Oct 2, 2013 | 02:14 PM
Rezonans's Avatar
Rezonans
Did you fix your problem?
Old Oct 2, 2013 | 03:48 PM
Lavrishevo's Avatar
Lavrishevo
Dirty throttle body can also cause this. its not a good thing for your car to idle too low. Oil circulation and power to the accessories is important.
Old Oct 4, 2013 | 11:52 PM
KING's Avatar
KING
CL Folding 25,000
Disconnect your battery for 24 hours. The RPM will return back to it's normal place. That's what worked for me.
Good luck!
Old Oct 5, 2013 | 07:12 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
clean you t/b then disconnect your battery for 15 minutes then take it for a drive.it may run a little rough for a couple of minutes as it burns the cleaning compound out.
Old Oct 5, 2013 | 10:54 PM
Rezonans's Avatar
Rezonans
I cant fix this problem, I did so many things but the RPM stays the same low, I did clean the throttle body, change spark plugs for ngk iridium, clean MAF, put lucas fuel igector cleaner, 2times disconnect battery, look for the air leak in intake, no luck.
Actually the problem appears, after I disconnect the battery, for 1 time after I bought the car.
Cant get after 200 mile run, evap system monitor ready.
Old Oct 6, 2013 | 06:01 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
you could go to the dealer and have the ecu reflashed.
