Lower Control Arm Bushing Repair
https://www.clublexus.com/forums/ls-...ovement-2.html
The bushing in the replacement bracket is pressed in up-side-down. The nipple should be in the downward position. The top half of the OEM bushing is "harder" to account for the downward load of the vehicle such that the bushing provides the same dampening characteristic in both up and down direction.
But then again, if the bushing is an aftermarket, it may very well be just a solid piece of rubber. In that case, the nipple is there just so that it looks like the OEM.
I oriented them this way because the outside bolt was larger and I had to flip them around, the only other thing I can think of is that i mixed up the driver side and passenger side.
These are the OEM IS bushings (48075-30030), same part as post 181, ordered directly from mylparts.com.
Last edited by Marston; Oct 9, 2018 at 04:29 PM. Reason: Used a proper PC instead of crappy cell phone
48075-30030 RH Passenger side
The last picture on post 181 shows the bags with TWO different part numbers, FYI.
I have pics of lower control arm bushings that mechanic said may need replacing. It is expensive. First two are from Nov 2017 and second two are from Jun 2018. A few things.
- Ride is a little bumpy and wobbly when braking as seen can be symptoms of bushing issues. Ride does not feel as smooth as it should.
- I am new to DIY on cars. So far I only have done a headlight cleaning and want to paint a big paint scrape on door that happened in a parking lot.
- Wondering what tools are needed for this repair and how hard or long it will take.
- As stated in the above post; will IS OEM parts work in LS? the ebay links are for that and GS.
- any other feedback would be appreciated
Thanks!
nov 2017
nov 2017
jun 2018
jun 2018
They will have Lexus OE for $80, and the same part, different color, $190. I've asked why?
The explanation to me was these are 100% legit OE Toyota parts. Why one is $80, and the other is $190, is the $190 came from a USA distributor, the $80 did not. This mimics the gray market that existed on cars and cameras in the 1980s. A camera shop would sell two identical new in box never opened factory sealed cameras, and ask you which you want. The gray good, for significantly less, with no USA warranty but honored by our store (the stores still exist today), or the USA warranty, where it's warranted by Nikon Canon Minolta (lol) Pentax Leica and where you can take it anywhere to be fixed. Nothing is underhanded, totally transparent. Same with these auto parts, they are not knock offs.
What would not be legit is say watches for sale online where the ser# was scratched off. They are still often legit products, but now we're into a new level of gray market that should be avoided...
