Under Engine Cover?
Old Sep 8, 2009 | 06:57 AM
cenwesi's Avatar
cenwesi
Default Under Engine Cover?
Does anyone know where i can buy an under engine cover?
Old Sep 8, 2009 | 10:10 AM
AlexusAnja's Avatar
AlexusAnja
The plastic protective panels underneath? Either at junk yard or at Lexus. Doubt someone would make non OEM for that.
Old Sep 8, 2009 | 05:42 PM
jman-LS430's Avatar
jman-LS430
I replaced mine recently since I am a stickler for detail and my original had scratches on it from the PO. I went ahead and purchased mine from the dealer. Got a little discount on it, but still paid around $150 for it.
I have my original one if yours is so bad off you would consider a used one.
Actually, most folks would consider the original one to be in very good shape.
Old Sep 9, 2009 | 05:07 AM
AlexusAnja's Avatar
AlexusAnja
That's what I call a stickler alright... under the car too. So what happens when you scratch it the first time? You'll change it again? If so, I'll take your seconds one as mine is pretty scratched up...
Old Sep 9, 2009 | 07:49 AM
jman-LS430's Avatar
jman-LS430
If I do it, it is different
I don't plan on scraping it. If it does scrape, that means my bumper was scraped as well, and that would be even more of a bummer. I know, it is bound to happen, but I can wish can't I?
BTW, when I first purchased the car, I immediately replaced the four rubber undercarriage deflectors (not sure what they are called) that are at all four corners next to the wheel wells.
Old Sep 9, 2009 | 08:33 PM
AlexusAnja's Avatar
AlexusAnja
Default Mini what?
... BTW, when I first purchased the car, I immediately replaced the four rubber undercarriage deflectors (not sure what they are called) that are at all four corners next to the wheel wells.
Ah, those two... what the heck are they for? Can't be mini-mud flaps because they surely don't deflect anything.
Old Sep 10, 2009 | 05:21 PM
jman-LS430's Avatar
jman-LS430
Rear set is labeled Rocker Protector
The front set labeled Front Wheel Pad
Old Sep 10, 2009 | 05:52 PM
jman-LS430's Avatar
jman-LS430
Default pix of the under engine cover
Here are the pix of the engine cover plate. This is the piece that you are talking about right?
Attached Thumbnails Under Engine Cover?-enginecover1.jpg   Under Engine Cover?-enginecover2.jpg
TCM55
IS F (2008-2014)
Jun 3, 2021 12:28 AM
08wis250
IS F (2008-2014)
Jun 16, 2015 05:52 AM
jbl-1985
Sep 9, 2011 08:51 PM
SC3coupe
Jul 7, 2010 04:38 PM
