Mirrors no longer adjust
Old Oct 28, 2009 | 06:35 AM
Yaff's Avatar
Yaff
Originally Posted by tcjeffri
This is one of those fixes that I believe 75% of the car loving population can handle. Its easier than changing oil, if you can handle oil changes, you can breeze through this fix. The key is making sure you have the right tools (small screwdrivers, contact cleaner, and Q-Tips). Let us know how it turns out!
I'm in RC Helis, so I think I can handle it :-)
I don't like surprises with no blueprint to tell me what's in the black box.
I'm going to give it another shot.
Do I need to take out the screws at the bottom?
I was only trying to unsnap the top (5 "clips" all around)
There is also some sort of round flat fuse at the bottom.
Stay tuned.
Old Oct 28, 2009 | 06:49 AM
tcjeffri's Avatar
tcjeffri
Do I need to take out the screw at the bottom?
Stay tuned.
I removed 2 screws at the bottom. Once you get that "housing" off, you will see that its very intuitive.
Old Oct 28, 2009 | 07:44 AM
Yaff's Avatar
Yaff
Talking
Mission successfully completed!
And no casualties... This thing now works like a charm.
Guys, make this one a sticky. It saves us from an hour of labor to clean the switch to 2 mirrors + a switch ~2000$ all depending on dealer integrity.
Took couple shots while the switch was opened.
The board (notice the grease in center... I didnt have any conductive grease to replace... So I left some)
The switch (Rubbed the contacts with fine glass sandpaper then clean with q-tips)
And clean the contacts on the "gasket" with q-tips.
I'm happy
Oh... this forum shows pictures in attachments as well. Oh well.
Attached Thumbnails Mirrors no longer adjust-board.jpg   Mirrors no longer adjust-switch.jpg   Mirrors no longer adjust-gasket.jpg
Old Oct 28, 2009 | 07:50 AM
tcjeffri's Avatar
tcjeffri
Awesome shots Yaff, glad it worked out for ya!
Old Oct 28, 2009 | 07:55 AM
Yaff's Avatar
Yaff
Thanks man, with your advice, I went there with confidence.
I was in and out in less than 10minutes.
Old Apr 8, 2010 | 05:26 PM
dubsta1's Avatar
dubsta1
this was a life saver for my 02 ls..dealer wanted $250
Old Jun 24, 2010 | 03:48 PM
GS3Tek's Avatar
GS3Tek
bump for this thread since I just did mine today and for the great pictures from yaff
Old Jul 17, 2010 | 07:27 AM
Dailow's Avatar
Dailow
Just wanted to thank you all for this thread!
My car was having issues with the switch as well. The right side was a bit intermittent and I had to try selecting it a few times before it would adjust. The left side was odd too because I could adjust it fine in any direction EXCEPT for up.
I didn't have anything to clean the switch with, so I ended up taking it apart and then putting it back together again. Not sure what happened, but everything is in working order again.
Old Jul 18, 2010 | 07:39 PM
jman-LS430's Avatar
jman-LS430
My '05 was still under warranty and I took my LS into dealership and told them that I wanted the switch replaced. There was no need to change out the mirrors since they were replaced when I bought the LS back in '08. I played around with the switch, cleaned it, etc, but even with the switch out and still connected, it intermittently worked. Needless to say, they dealership still replaced both mirrors AND the switch. Gotta love it. It was just easier for them to do that.
The only pain I had was since I had the turn signal covers, I had to take those back to the shop to have those reinstalled.
Old Jul 21, 2010 | 05:07 PM
motohide's Avatar
motohide
Yeah, with most cars, switches that get used very seldom, like the mirrors and AFS/VSC on LS430, sometimes corrosion or fungus settles on the switch contacts. This renders the contacts to have a bad connection inside the switch as its only lightly spring loaded. Cleaning them with things like "electrical contact cleaner spray" sold at Radio Shack or Fry's usually cures them temporarily till it develops again. If you remove and clean them manually, be sure to use some anti-corrosion additive and solvent to wipe it free of oils and other matter that might introduce molds and corrosion.
Old Jul 21, 2010 | 05:32 PM
stvincent's Avatar
stvincent
having the exact same problem. mine is CPO, but was wondering if this is a big issue. thank you for this post.
Old Dec 12, 2010 | 08:04 AM
gemineye's Avatar
gemineye
Thumbs up Side mirror woes SOLVED!!!
I was experiencing the EXACT same problem(s) as the original poster was having. I followed the advice of those that replied to this thread, and wa-la.......problem solved!!!
Much thanks to the original poster, those that posted directions on how to solve the problem, and those that took the time to take pics and post them up. I saved myself plenty of dinero, as well as the headache of having to take my car to the stealership.
Randy G.
'02 LS430
Old Dec 16, 2010 | 02:12 AM
subtracted's Avatar
subtracted
I did this to my 04 a month ago. Worked like a charm! Local dealer was recommending a new master switch for about $250 + two new mirrors for $1,200!!! Fixed for free
Old Dec 28, 2010 | 04:01 PM
Roger430's Avatar
Roger430
Thanks to everyone on this thread.
One hour ago neither mirror worked and I was hoping to find a blown fuse. My wife has bent the passenger side mirror back while backing out of the garage on more than one occasion, and I thought that if I didnt find a blown fuse, it might be dead from the impacts.
I found this thread, and the photos really made it a no brainer. I took the switch out, took it apart, cleaned the contacts, and works like new.
Thanks again.
Old Dec 31, 2010 | 06:31 AM
raffles's Avatar
raffles
I had a similar problem and discovered my battery was dying causing the mirrors not to work even though the car would start.
