check engine light
Old Jun 23, 2009 | 06:54 AM
David M's Avatar
David M
Default check engine light
The check engine light just came on at 59,134 miles. Is this a routine thing? Can I pick up an OBDII scanner and find out what the computer is saying before having a shop charge me a million dollars to do the same thing?
Thanks,
David
Old Jun 23, 2009 | 08:43 AM
BrianJ's Avatar
BrianJ
No, not normal. Stop by Autozone to get the code(s) read at no charge.
Brian
Old Jun 23, 2009 | 11:23 AM
AlexusAnja's Avatar
AlexusAnja
Not normal and you can use an OBDII reader as the LS430 is OBDII.
Old Jun 23, 2009 | 01:01 PM
JBLover's Avatar
JBLover
Go to autozone or almost any other auto parts store and have them pull the code for you, then we can look it up and post what may be wrong. It could be minor or major. You never know. Autozone will do it for free.
Old Jun 23, 2009 | 01:55 PM
speedemon's Avatar
speedemon
If you pull the codes or have someone pull the codes beware of the vsc/vsc off light that may come on after you clear it and take a test drive. there is a post that others have posted as well at the one I posted about a DIY for Oxygen Sensors that goes into detail on the 2 pins you need to jump to clear that light if it gets set. https://www.clublexus.com/forums/ls4...ensor-1-a.html
Good luck.
Old Jun 30, 2009 | 03:44 PM
David M's Avatar
David M
Took it to Autozone as per you guys suggestions. No trouble codes! Well, I tinkered around with the "info" menu and lo and behold it's just a change the oil message. What a relief!!!
Thanks for the help, all y'all!
GBunce
Jan 9, 2024 09:11 AM
ry2216
Oct 5, 2020 10:02 AM
rustyd
May 2, 2014 06:29 PM
relax221
Jul 24, 2009 06:59 AM
abear2007
Maintenance
Mar 14, 2007 02:20 PM
