VSC Light
Old Apr 28, 2014 | 08:43 AM
rustyd's Avatar
rustyd
Default VSC Light
This and the check engine light came on when I started the car this morning. Its an 06 GS300 with just under 53K miles....any hints on what it would be and how much it is to fix ? Going in on Wed to be looked at. Thanks,
Old Apr 28, 2014 | 11:29 AM
BurgBoxstr's Avatar
BurgBoxstr
maybe your cologne?
Seriously, any hints (aka guesses) wouldn't be worth your time reading w/o more info. You can wait until Wed for your service appt or.... go to any national auto parts store (Advance, AutoZone, O'Reilly, etc.) and they will pull the OBDII diagnostic codes absolutely FREE. Code(s) will read like this: P_ _ _ _ (4 digit #) and most times whoever pulls them can also suggest a POSSIBLE cause (and/or look it up based on model in their computer). .
Post back (or search the forum) w/ the diagnostic code(s) given. If you ask nicely (and it's not a serious code and you have a good clerk) they may reset/clear it for you too. Even if you have an appt I'd still do as there's nothing wrong w/ you have a little info before a tech (who may or may not be well trained) starts testing fixe$ and part$ at your expense (particularly important when an error code is O2 sensor related. All that code means is value reported by sensor is out of spec. Many an unscrupulous shop will simply start by replacing sensors at $100+ per w/ labor only to find that doesn't fix the underlying problem.... as it could be so many other things).
Good luck
Old Apr 28, 2014 | 12:13 PM
IXI187IXI's Avatar
IXI187IXI
gas cap...
Old May 2, 2014 | 02:09 PM
rustyd's Avatar
rustyd
It was the Gas Cap! They first thought it might be the Charcoal canister, but thankfully it wasn't.
Old May 2, 2014 | 02:50 PM
XxGoKoUxX's Avatar
XxGoKoUxX
was gonna call it but ixi beat me 2 it loool
Old May 2, 2014 | 06:29 PM
Schmexus's Avatar
Schmexus
I can't believe how often it's the gas cap. Probably drives dealerships crazy...
GBunce
Jan 9, 2024 09:11 AM
DAbernathy
GX - 1st Gen (2003-2009)
Jul 14, 2019 04:13 PM
BPVIP
13
May 7, 2012 03:08 PM
relax221
Jul 24, 2009 06:59 AM
David M
Jun 30, 2009 03:44 PM
