hearing clucking sounds.
Old Dec 31, 2008 | 02:11 AM
03 LS 430's Avatar
03 LS 430
Default hearing clucking sounds.
happy new year to all..im having this on going problem with my front right side.. when rolling over bumps small or large i be hearing this clucking sound..its not the struts or shocks. i dont want to spend crazy money on something that wont solve the problem. my new front tires are feathering on the outside and i need help fast..help help help
Old Dec 31, 2008 | 02:16 AM
drink300's Avatar
drink300
clucking? Are you sure there is not a chicken stuck in your engine compartment? LOL...
I had a similar problem with my 03 LS. I took it to lexus several times and they never fixed it completely. They replaced a myriad of components and nothing ever fixed it. They replaced some bushings (can't remember, it's been so long) and that made it better for a while.
So, hopefully someone here can help you, because I assure you, the dealer is going not going to be a great help if your situation is anything like mine was. Luckily, I was on lease, so I was able to get rid of the car. The replacement - my 04 LS - has Air Suspension and I have never been happier.
Old Dec 31, 2008 | 06:37 AM
junjdm's Avatar
junjdm
does it happen everytime you go over a bump?
that doesn't sound too good...
Old Dec 31, 2008 | 07:59 AM
Rice's Avatar
Rice
It's not rocket science.
First of all, start off by NOT going to Lexus. Find a good local mechanic and save $$$.
Second, there is a finite number of things that can cause the noise. I will list them in the order of decreasing probability:
1 - Upper control arm bushings
2 - Ball joint
3 - Strut bar bushings
4 - Sway bar bushings and/or links
5 - Upper strut mount bushing
6 - Strut itself
7 - A bottle of scotch in the glove box (ask me how I know)
Once the cause has been identified and fixed, do a wheel alignment and tire rotation.
Good luck!
Old Dec 31, 2008 | 09:16 AM
airtime's Avatar
airtime
CL Folding 1,000,000
You must of drank it till its empty for you to hear it cluck
Old Dec 31, 2008 | 10:01 AM
GS3Tek's Avatar
GS3Tek
2 - Ball joint
6 - Strut itself
Good luck!
I agree to what Rice said.
And if the tires are feathering fast, then definitely suspension-related.
Make sure the chicken didn't lay an egg somewhere and it's rolling around making that noise
Old Dec 31, 2008 | 10:25 AM
03 LS 430's Avatar
03 LS 430
yeah it does
Old Dec 31, 2008 | 10:28 AM
03 LS 430's Avatar
03 LS 430
2 - Ball joint
6 - Strut itself
Good luck!
yeah just got it checked out and they said its the lower control arms bushings some big round rubber surounded by metal barcket.
Old Dec 31, 2008 | 10:32 AM
03 LS 430's Avatar
03 LS 430
well alright im happy for you i need to up grade to a 05 ls soon
Old Dec 31, 2008 | 10:43 AM
Rice's Avatar
Rice
Does it look like #5 or #6 below?
The difference is about $160.
Ask them to check out the other side as well. Chances are it is in the same condition or will be very soon. Doing both sides will save you an extra wheel alignment.
Old Dec 31, 2008 | 02:33 PM
03 LS 430's Avatar
03 LS 430
INFACT I ROLLED OVER A BIRD AND STILL SEE THE FEATHERS WHEN I REV IT UP
Old Dec 31, 2008 | 02:43 PM
03 LS 430's Avatar
03 LS 430
Wink
Originally Posted by rice
does it look like #5 or #6 below?
6.. Why you gots the hook up ineed two
Old Dec 31, 2008 | 02:44 PM
03 LS 430's Avatar
03 LS 430
That doesn't sound too good...
i know that y im tring to find out whats going on
Old Dec 31, 2008 | 10:02 PM
big_blzr94's Avatar
big_blzr94
that pic does not look like the 03 LS front suspension they are probably talking about the rearward lower control arm bushings with the carriers that adjust caster.
Old Jan 1, 2009 | 12:04 PM
Rice's Avatar
Rice
The picture was taken from 05, which is the same as 03 and 95+ as a mater of fact. There is no traditional lower control arm. Instead, LS is using a strut bar for softer ride. Personally, I would prefer traditional double wishbone setup, but what do I know
