Power drivers seat
Old Nov 11, 2008 | 03:34 PM
stubbs836's Avatar
stubbs836
10th Gear
Default Power drivers seat
When the key is turned off the mirrors and steering wheel retract however the seat does not move back making it easier to get out. Should not the seat retract somewhat? My chrysler 300M does so I expected the Lexus to do the same.
Old Nov 11, 2008 | 03:58 PM
SH212's Avatar
SH212
Dances with goats
Mine doesn't... i think 04's and up can do it because i've seen it before but i know my 01 cant.. what year is your car?
Old Nov 11, 2008 | 04:55 PM
AlexusAnja's Avatar
AlexusAnja
Default Steering wheel
Nope, unless it's a CBEST setting, my '04 does not retract the seats. Only mirrors fold (if you set the mirror adjust to left or right) and steering wheel retracts. Seats stay the same, and honestly, unless you're either very tall or very "round" then retracting the steering wheel is enough to give extra room to move out from your normal seating position.
Old Nov 11, 2008 | 05:03 PM
stubbs836's Avatar
stubbs836
10th Gear
Mine is a 2006 LS430
Old Nov 12, 2008 | 04:54 AM
AlexusAnja's Avatar
AlexusAnja
Default The BEST...
The "best" year... ha ha. No idea, but when I was purchasing, I only tested '04 and '05 and none of them retracted back. Unless it was added JUST for '06, then probably not also...
Old Nov 12, 2008 | 06:51 AM
Kansas's Avatar
Kansas
You are not the first Chrysler driver who has asked this.
If you have difficulty getting out of your LS430, consider using memory button 3 to position the seat to an "exit position" before you get out. Some drivers set the seat cushion to maximum height to make it easier to get out.
Maybe it's what you get used to. If I remember correctly, it was an Infinity M35 I rented for a couple of weeks on vacation that automatically moved the driver's seat back when I pressed the "engine off" button. I hated that feature and the M35 in general. The seat was so far back that the door post was in the way of getting out.
Old Nov 12, 2008 | 06:32 PM
AlexusAnja's Avatar
AlexusAnja
Default Smart Move
Originally Posted by Kansas
... If you have difficulty getting out of your LS430, consider using memory button 3 to position the seat to an "exit position" before you get out. Some drivers set the seat cushion to maximum height to make it easier to get out...
Good idea. My button 3 is actually not doing anything. The first time I hit the button, I thought my car may had previously been owned by Shaq, it was full back and down low.
If you have SmartAccess, you can set your FOB to auto adjust to your setting once you enter the vehicle. So, if you press "3" to get out, when you enter, the car will be waiting for you in your set position.
Old Nov 13, 2008 | 07:13 PM
bigcory's Avatar
bigcory
I just did this with my button 3. I was annoyed that when I put the car in park and opened the door, the wheel did not retract. Like when you dropping off movies or have to get something out of the trunk. So I set my 3 to have the wheel retracted all the way. Helps alot, especially since i'm kinda "round"
Old Nov 13, 2008 | 07:22 PM
bigcory's Avatar
bigcory
Old Nov 13, 2008 | 07:32 PM
KILLERGS4's Avatar
KILLERGS4
no car is perfect, i think it is cbest settings "lexus personal setting" have to take it to the dealer for this if you must...
Halebob
Feb 22, 2019 02:28 PM
jimisbell
Feb 6, 2018 09:35 PM
tpjc1018
Jun 5, 2014 12:10 PM
KSLS
Jun 12, 2007 08:02 AM
smalcom
Apr 26, 2003 10:52 AM
