Car Cranking Problems
Old Sep 18, 2008 | 11:40 PM
JemmyTran's Avatar
JemmyTran
Default Car Cranking Problems
So I just got my electricity restored Since Hurricane Ike hit. I drove my car through about 12 inches of water and car was fine. Two days later I tried to crank my car on and does not start. So i got the other car so that i can jump start the LS430 and before i jump start the car I tried cranking it again and it worked. Then later that day I tried cranking it again and same thing happened after 4 tries the car cranks. The next morning it cranked after 3 tries. What do you think it could be the battery or the alternator?
Old Sep 19, 2008 | 04:17 AM
Haylands's Avatar
Haylands
Hi
Glad your back on line I hope you didn't get too much damage from Ike...
First the 430 is not designed to go anywhere near 12" of water so it will have got water in all sorts of places it shouldn't have.
If I were you I would inform your insurance company of the car issues as leaving it till later may effect a claim (if you are covered for damage like this)
But you will probably find that after a few runs it will dry out on its own and be OK, I'd take it for a good long run 50-75 miles to get it good and hot, then leave it ticking over for a good while to raise the underbonnet temp to dry everything out. If that doesn't work its an auto electrician to check the alternator/started circuit.
Good Luck
Pete
Old Sep 19, 2008 | 04:35 AM
AlexusAnja's Avatar
AlexusAnja
Default Shorting
Originally Posted by Haylands
Hi
Good Luck
Pete
I agree that something is just wet and shorting out. If it doesn't work, it should just not work, not work and sometimes not work. If you did not have this issue before then that's how it is. Like Pete said, let it run a while and warm up and dry out.
Old Sep 19, 2008 | 10:44 PM
JemmyTran's Avatar
JemmyTran
thanks for the info guys i will try that
hnlcelsior
Aug 3, 2022 01:41 AM
Gustavo621
Dec 3, 2015 12:25 PM
sc-fsport
Jun 16, 2015 01:09 PM
dhamaka127
Jul 4, 2007 09:44 AM
TTCUPS
Mar 2, 2005 02:48 PM
