2001 LS430 Navigation Override
I know this has been posted before but I can't seem to make it work. I have a 2001 LS430 and I believe the Navigation is Generation 2/3. I cannot figure out how to make the override work to activate the navigation menus when driving.
The volume selection does not have a distinct menu on my navigation so that trick doesn't seem to work.
Any help would be appreciated.
What version are you running?
press Menu [NOT OPTIONS] then select System Options.....when you get to that screen, press upper left, lower left, upper left, lower left then lower right....you will get the tech screen. There you select the options you want.
All this can be found at https://www.clublexus.com/forums/sho...14&postcount=8
Here is a link to YOU TUBE showing you how to do it..
http://www.youtube.com/watch?v=ysXzM9t7erQ
If the link does not work just search YOU TUBE for NAV OVERRIDE
I got it to work with the up top left, down lower left, up top left, down lower left, down lower right. That takes me to the override and it works.
I am now seeing that the override still works with the latest disc on the 2001 LS430 navigation. Any truth to this?
The older versions are fine.
Apparently it works with the newer versions too. That's actually what I was trying to find out in another post.
