Headlight problems
Old Jul 23, 2008 | 10:15 AM
Munki's Avatar
Munki
Default Headlight problems
Recently i've been having some probs with my driver side head light. First of all, the light is white and the passenger light is blue. After driving my car for about 30 min the driver side light will flicker and later go out. I have no clue as of what’s causing this... I don't think it’s the bulb because it comes back on once I turn the lights off and back on.
Have any of you guys ran into this problem? If so, what actions did you take to fix it?
Old Jul 23, 2008 | 11:02 AM
GS3Tek's Avatar
GS3Tek
If you're positive it's not the bulb, then it's the ballast.
To be sure, switch the bulbs to the other side.
I'm assuming you're talking about the LS since you have an IS and GS in your profile.
Old Jul 23, 2008 | 11:31 AM
Munki's Avatar
Munki
Yeah, this thread is for the LS430.
I'll swap the bulbs when I get off work to make sure. And where would I buy a new ballast? If I have to replace the ballast, would that be an easy install?
Old Jul 26, 2008 | 10:01 AM
GS3Tek's Avatar
GS3Tek
Anything is easy if you've done it before
The ballast is located under the headlight and to get to it, you'll have to remove the bumper.
This is what a ballast looks like (if you haven't seen one):
It's enclosed inside the headlight cover.
Pictures stolen from ebay-this one showed the ballast removed:
starstreak
Oct 3, 2018 01:45 AM
Zinda
Apr 14, 2015 09:37 AM
Jaybeck860
IS - 1st Gen (2001-2005)
Jan 27, 2014 11:08 PM
UNCGS06
Oct 11, 2010 10:19 AM
cknjohnny
Jan 28, 2010 05:07 PM
