Lowering Instructions and Tips
Old Mar 16, 2008 | 07:44 PM
KINGLS430's Avatar
KINGLS430
Question Lowering Instructions and Tips
I'm loooking for detailed Lowering instructions for a 2006 430 UL. I thought i saw it earlier but am unable to find detailed instructions with pictures and any tips you guys have for me i'm going to attempt this within the week i presently have my stock 16's on for the winter and am worried about a little rubbing especially with the back i will post pics tommrow so you guys can give me an idea. Switching to summer 18's soon trying to go 1 inch all around or maybe a little more like i said looking for guidance and any tips at all i am not a mechanic at all and am afraid to %$#@ this up. Thanks......
Old Mar 17, 2008 | 07:33 AM
motohide's Avatar
motohide
You can adjust the ride-height sensor on each of the four suspension links on the Air Suspension Ultra Package LS430. Though be careful as tampering with it haphazardly can snap these sensors at very low adjustment points and are VERY expensive to fix, replace!! Also, this method has limitation where OEM controller can only go UP in height very little so if you tweak the sensor, you are pretty much stuck at low height, if you set that up as a base NORMAL point and HIGH setting will only raise it slightly. Also, the OEM controller also varies height automatically during driving so you may see erratic height resulting from computer making automated adjustments while moving.
However, the BEST and safest way to do it is to use a DATASYSTEMS Air Suspension Controller ASC680 (available for about $600~900) online at many places) to do this at the Suspension ECU, so that all Lexus warranties are not voided and you can basically return it back to stock by hitting a switch. With this, you don't even have to get dirty...just find the Lexus Suspension Commputer, plug it in, and hit a switch and see your car go up and down at your command!
Old Mar 17, 2008 | 09:36 AM
KINGLS430's Avatar
KINGLS430
I understand the buying the controler would be smarter. However i am chosing to follow this path. If i lower the car only 1 1/4 inches in the front and 1 inch in the rear. Will the High mode put me up to the standard height that i am at now with no modifications? Furthermore When i go over 68 mph will the car lower itself even further? The reaso i ask this si because of rubbing with the stock 16's tha ti have on now and the summer 18's that stick out of the fender a little bit i don't want to be driving on the Garden state parkway and accelerate to 75mph and slice up my front 2 tires.
Old Mar 17, 2008 | 05:04 PM
KINGLS430's Avatar
KINGLS430
Front with stock 16's their tucked in nicely but lik i said im just making sure i have enough clearence if i go above 68 mph
Old Mar 17, 2008 | 05:06 PM
KINGLS430's Avatar
KINGLS430
Rear sits towards the front a little thats where my major concern lies there is about an 3 inches between the tire and the car
Old Mar 17, 2008 | 05:19 PM
blacksc400's Avatar
blacksc400
Car Chat Moderator
I got my controller installed, and also adjusted the sensors...
you think my height is good ? even if I drive over 60mph, lowing 1 more inch is safe?? Or should I press high when I drive on highway??? Haven't tried driving highway yet.
I still have 1 finger gap between the tires and the fender... is it safe?
Old Mar 17, 2008 | 11:47 PM
motohide's Avatar
motohide
It looks like you are using OEM sized 16" and 18" wheels and tires. In this case, lowering the car 1.5 inches should still be fine, no clearance issues or height issues... OEM size tires/wheels will not hit anything along the full stroke of the suspension.
However, going wider or over-sized diameter will tend to give lots of issues at the front tire/fender clearance so be cautious of that fact. You are good to go!
Old Mar 18, 2008 | 08:28 AM
KINGLS430's Avatar
KINGLS430
Thank you very much,
Since the rear sits down a little i will only be doing one inch in the rear and 1 and 1/4 inches in the front and see how it looks. The 18's are the 18's by 7.5. however they are custom wheels that require 5mm Hub centric spacers so they do stick out a little you might get an idea of what i'm talking about by looking at this pic. I know i have to adjust the sensors but how do i do that i can't seem to find any detailed information about it?
DaCelsior
Apr 12, 2019 07:37 AM
l33ks
Oct 6, 2016 11:08 AM
ancdmd
Jan 30, 2015 04:55 AM
Otterlex
Oct 30, 2011 06:29 PM
nicolachel
Jul 22, 2011 06:23 AM
