LS430 2005 Navigation change
Old Jun 30, 2007 | 02:41 PM
TrojanUAE's Avatar
TrojanUAE
Default LS430 2005 Navigation change
Hello guys
am new to this club and it's really well arranged
i just bought my LS430 2005 from USA , but i live in ( Dubai, United Arab Emirates ), So is there away how to change the Navigation system To work with United Arab Map.
Thanks alot
Old Jun 30, 2007 | 08:55 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Welcome to Clublexus!
7ayak!
First, you might need to get a local map DVD, and possibly change the region in the navi ECU, which can be accessed via going to the volume screen, then pressing top left corner, lower left corner, and top, then lower left corners again.
There will be another menu, and options you can use to switch regions. BEWARE! changing the firmware can damage your ECU, first, make sure you find out the region for the UAE area, (check another LS) then perform it on yours. The change is permanent, so be careful.
WORSE case scenario, is that you might have to buy a ECU from a Middle eastern spec LS from a junk yard, and install it.
Old Jul 1, 2007 | 01:16 PM
TrojanUAE's Avatar
TrojanUAE
Thanx alot ( GRAND LS ) ... i will try that..
another thing, that some people here in UAE have done it by inserting a CD in the Navigation box ( to load some data ) then they insert another CD to load UAE map !!!! but they charge about $500 to do it. !! any Clue !!
Old Jul 1, 2007 | 03:19 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Im not sure what that is, but whatever it is, its not worth $500 bucs. New DVD maps are usually $300-$400 dollars, and thats all i can think of. What other CD's are they inserting? do you know?
Old Jul 2, 2007 | 08:48 AM
TrojanUAE's Avatar
TrojanUAE
No idea what was the first CD , it's just a DATA CD , u can see it loading on the Navigation Screen.
by the way , the DVD map they provide u with is Copy not original
Old Aug 5, 2013 | 02:59 PM
Wezee's Avatar
Wezee
Default LS430 2005 Map DVD
Salaam brothers,
I live in U.A.E aswell and I would like to know if anyone of you know where I can get a UAE map DVD?
Old Mar 17, 2014 | 08:21 AM
amjadLS430's Avatar
amjadLS430
Hi peeps
i live in the UAE as well,in the Fujairah region and there are shops out here where u can get it done for 500 dhs...havent personally got it done but ive heard about it from friends and technicians!
A visit to any lexus garage will get u the address to the guy who does it!
Old Aug 20, 2014 | 01:19 PM
Rumphalz's Avatar
Rumphalz
hi guys i have LS430 2001 JAPAN specs from Germany imported in Dubai just want to change or upgrade the Navigation system for that i went to shop and they said because your car is from Germany and has japan navigation system so we cannot upgrade or change the map with DVD you have to change the whole navigation system from USA model then we can able to upgrade
is it right?
any suggestion that anyone know about this issue
Dirtyd210
Apr 14, 2010 01:14 PM
general98
Nov 2, 2008 09:55 PM
sunsolaris
Oct 5, 2008 09:02 AM
frotiss
May 9, 2008 11:41 AM
